Coby Wheel
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      02-12-2019, 04:49 PM   #221
behindthen0thing
behindthen0thing's Avatar
840
Drives: M4
thanks for the heads up on this. I checked mine out and it seemed ok. I'll definitely keep an eye on it from now on. wonderful knowledge on this forum
      02-12-2019, 07:32 PM   #222
ntg44
ntg44's Avatar
Drives: R8 4.2 Spyder
17 m3 base, 8000 miles. Not my daily so driven hard when taken out. No track days though.
Here’s a shot of mine. The level looks to be in the middle but the color is way more transparent than most I’m seeing here...kinda weird, almost looks diluted.
      02-12-2019, 07:34 PM   #223
WeekendWarriorz
WeekendWarriorz's Avatar
674
Drives: 2006 Z4M
Here's a shot of mine. The level looks to be in the middle but the color is way more transparent than most I'm seeing here...kinda weird, almost looks diluted.
Dip a paper towel in and you'll see the color of the fluid. Don't soak it just maybe 1 cm. It's okay to add a small amount of distilled water to fill it up and monitor fluid.
2006 Z4 M Roadster Black/Imola Red, FBO VF-Engineering, e85 Flex Fuel-Sold
2012 BMW 135i N55 DCT Alpine White/Coral Red, FBO, TBI, Full e85, JB4 BEF-Sold
2006 Z4 M Roadster Black/Black-Sold
2021 M2 Competition DCT Hockenheim Silver
      02-12-2019, 07:54 PM   #224
ntg44
ntg44's Avatar
Thanks. It’s 2 ticks below full, so can’t confirm if leaking yet. I’ll drive it hard until next gas tank or two and check again.
This kinda stuff makes me so paranoid. I doubt a real recall/fix will be implemented, and an expensive aftermarket replacement part shouldn’t be the only solution. Seeing the internals from original post, that looks awful. Doesn’t make me want to consider keeping the car after warranty expires. Guess I’ll stick with air-to-air intercooled engines from now on.
Appreciate 3
bplewis24188.50
KevM2724.50
      02-12-2019, 08:29 PM   #225
THEROK
South Korea
1274
Drives: Genesis GV80
That's how clear mine looks even after recently topping off w/ BMW OEM coolant. First time cracking open the charge cooler prompted only by a random click on this thread with the elementary school title.
Mine was on the bottom one or two notches. It's at BMW service now. If this becomes a repeat issue, either I'm dumping the car for a 991 GT3 or taking a $2500 gamble with an aftermarket unit.
Dry sump flat six
ntg442891.50
      02-12-2019, 10:55 PM   #226
mfurse
mfurse's Avatar
Australia
182
Drives: BMW F80 M3 2016 LCI
The new S58 engine video that BMW posted shows an intercooler that looks subtley different but the connections look roughly in the right places (from the video so it's hard to really tell).
Would be good if the OEM part was stronger / better and was a direct replacement! (Probably not).
      02-12-2019, 11:03 PM   #227
WeekendWarriorz
674
Drives: 2006 Z4M
The title got your attention so I'd say it's successful
minn1914078.00
      02-13-2019, 04:47 AM   #228
jmciver
///M SubDriver
jmciver's Avatar
Drives: 2017 M3, 2020 X7 40i
2017 BMW M3  [10.00]
2020 BMW X7  [0.00]
2019 BMW X3  [0.00]
2009 BMW 128i  [0.00]
Guys, while it is a good idea to more periodically monitor the charge cooler expansion tank level as a result of the info provided in this thread (I do now), there is no need to "panic" if your level fluctuates a few "ticks" in the band, as read on the yellow indicator in the expansion tank. Keep in mind that the water capacity in this system is relatively small at 3.9 liters (compared to the engine coolant system which is a whopping 13.9 liters).
What this means is that small temperature changes can cause the level in the expansion tank to rise or lower a few "ticks" within the normal operating band as read on the yellow indicator (which is not designed to be very accurate in the first place). For example, my charge cooler is not leaking (knock on wood) and I had my expansion tank filled to just below the high level mark. When it got really cold these past few weeks (even in my garage - my engine coolant and oil temp got down to the mid 40's deg F after my car sat for a few days), the level in my charge cooler expansion tank was noticeably a few ticks lower, but still within band.
In other words, if you check your tank level when your engine is hot vs warm vs cold, you will see slight level changes in your expansion tank - but if your tank is not leaking, they should all still be in the normal operating band. In fact, it is a good idea to keep your expansion tank level at the low end of the band when the car is cold so that there is plenty of room for the coolant to expand when the car is at normal operating temperature and not overflow (which it can do). So unless you see a significant level drop over a short period of time (i.e. the expansion tank is dry or close to dry) then you should be fine.
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior
X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic
X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's)
Appreciate 5
ntg442891.50
arashir164.00
shay2nak1070.00
      02-13-2019, 06:48 AM   #229
ntg44
ntg44's Avatar
^^I didn't even think of that. Thank you for basically eliminating my anxiety about this thing haha. Being in Chicago, car hasn't even left the garage in these -20 to +20 temps. Would make a lot of sense. Best thing to do is just check periodically to make sure this isn't becoming a problem.
      02-13-2019, 10:47 AM   #230
Wolverine M3 CS
Wolverine M3 CS's Avatar
Drives: 2018 M3 CS, 2016 M4 ZCP
I took my car to the dealer Yesterday and they did find that it was leaking, they are replacing the unit, I asked for the old part but the dealer said there is a note from BMW to hold the part for inspection. Maybe they are finally realizing that there should be a recall.
2018 M3 CS,2016 BMW M4 ZPC sold, 2016 BMW M235I,
Appreciate 2
      02-13-2019, 05:25 PM   #231
THEROK
South Korea
1274
Title should be revised, but many of us appreciate you for bringing this to our attn no doubt. More people should be keeping an eye out.
That's why any brain cell(s) endowed owner should be checking levels while minimizing variables. I checked mine after the car's been sitting overnight in the garage. 24 hours later, checked again. Level was topped off as the day before. Drove around at higher than normal revs at freeway speeds and aggressive off the line bursts covering ~10 miles. Let it sit again overnight. Coolant level was down ~3 notches.
BMW service tech just verified that mine was indeed leaking. New charge cooler ordered. As a precaution, I asked them to perform an oil service 3K miles early. My intervals are off anyways since I swap out engine oil ~5K miles.
Dry sump flat six
      02-15-2019, 11:10 AM   #232
Wolverine M3 CS
I just got my car back from the dealer, they replaced the unit and did find coolant inside of it, I asked to replaced the spark plugs as well, no oxidation found on them, Wow what a difference it makes to have new spark plugs. I am replacing them more often. Hopefully, for all of us, the new intercoolers have the problem fixed. But, if any of us that have already change them notice something wrong please let us know if the problem comes back again. I am probably going to get the other intercoolers mentioned on this thread and have the OEM as a replacement. Good luck everyone and thank you all again.
shay2nak1070.00
      02-15-2019, 11:25 AM   #233
parabmw
169
Drives: 2018 m4
If this is a common problem shouldn't bmw have fixed it a later models?
Is it happening in 2018s?
      02-15-2019, 11:37 AM   #234
jmciver
///M SubDriver
jmciver's Avatar
2017 BMW M3  [10.00]
2020 BMW X7  [0.00]
2019 BMW X3  [0.00]
Not necessarily. It depends on how "big" the problem is according to BMW's problem "criteria" - and I don't know what that criteria is. Without access to the true failure data, we will never know. That said, if BMW did do something, an indicator could be a part number change for the charge cooler and/or an SIB documenting the issue and the approved factory fix which could be as simple as ordering the "new and improved" part.
      02-15-2019, 11:51 AM   #235
shay2nak
smoke if ya got 'em
shay2nak's Avatar
Drives: F80 M3/Lotus Exige/500 Abarth
That's great! How many miles on your car?
      02-15-2019, 12:59 PM   #236
Wolverine M3 CS
28453 with 14 track days. I love it so far...
shay2nak1070.00
      02-15-2019, 02:32 PM   #237
WeekendWarriorz
674
Drives: 2006 Z4M
Yes it's happening in 2018s, that's what started this thread was my buddies 2018 F80 M3. I hope everyone knows that the replacement that BMW is putting in is the exact one that has failed previously. Part numbers are the same, hopefully they will revise them but time will tell.
      02-28-2019, 04:04 PM   #238
KevM2
KevM2's Avatar
725
Drives: 2019 F87 M2C, 2023 G87 M2
BMW M2 Competition  [0.00]
  [0.00]
Is an aftermarket one like the CSF 100% fail proof? My guess probably not but at least it's much more robust than the BMW one... only problem is that it would void warranty... then again, if it's much better then there should be no need for the warranty
      02-28-2019, 04:15 PM   #239
WeekendWarriorz
674
Drives: 2006 Z4M
I'd assume so, it has a stronger core and better fins. Better material. I believe we have yet so see one fail.
      02-28-2019, 05:48 PM   #240
milk242
184
Drives: Car
Bar and plate radiator cores are supposed to be stronger and more efficient from what I've read (not a engineer so I can't say for sure) compared to the tube and fin design of the OEM radiator core found in the intercooler.
14 Audi S4 (sold)
16 BMW M3 (sold)
16 VW Golf GTI (sold)
20 Tesla Model 3
23 Audi R8 (on order, never came )
      02-28-2019, 11:01 PM   #241
KevM2
KevM2's Avatar
725
  [0.00]
Originally Posted by avex8 View Post
If you got the money and going to keep the car for awhile, go with csf or eos, they are lifetime warranty. I have the factory warranty but decided to upgrade my intercooler because my SA told me it's pretty common issue, so no point to put a defect design oem intercooler unless you are leasing the car
Which would you recommend, CSF or EOS? Or both are equally good so go with the cheapest?
      03-01-2019, 06:49 PM   #242
overlook637
247
Drives: M4
nothing is fail proof.
ntg442891.50
f80post
