12-22-2023, 09:32 AM | #23 | |
41
Rep 131
01-31-2024, 05:10 PM | #25 |
IG: @M5RCY_
365
Rep 318
Do you have a CF roof or sunroof?
Autotecknic.com - code: M5RCY for 12% off
Project Gamma - code: M5RCY for 5% off Dura-Coating - code: M5RCY for 20% off |
02-18-2024, 08:44 PM | #27 |
91
Rep 131
02-19-2024, 09:58 AM | #29 |
167
Rep 221
Inbox is full. You were right. The rear deck speaker works in the door. Now I'm having a hell of a time getting the upper panels back in place. Looks like they have to slide on to the guides, but it not easy with the metal clip in the way. Also after i got the rear deck off it looks like the grills for the rear decks come off?
Edit, looks like there's 3 speakers out. The 2 front doors and the driver's side rear. Not as bad as I thought. Last edited by S EyeLand; 02-19-2024 at 10:18 AM.. |
hookson90.50 |
03-20-2024, 09:27 PM | #30 |
Rep 29
Ugh, stereo sounded terrible, found this page, and sure enough both my front mids are out.
Anyone have any idea how much labor it is to replace these? Didn’t find a great video on pulling the door panel off. Will definitely order the kit from this thread, but not comfortable doing the work myself. I’m accident prone :-) -Collin- |
03-20-2024, 09:32 PM | #31 | |
167
Rep 221
03-21-2024, 03:25 AM | #32 | |
91
Rep 131
I include the new clips with the order of speaker protector and speaker https://youtu.be/x7BDUI0tz8s?si=g2vTNU4WfvZX0zVi |
03-21-2024, 07:40 AM | #33 |
82
Rep 136
I replaced all the speakers with parts from hookson. i did find on the rear doors you can pry the bottom panel loose and pull enough to get at the speakes without panel removal. Just need another body to hold for the minutes it takes to replae speakers.
hookson90.50 |
03-21-2024, 11:28 AM | #34 |
988
Rep 1,806
My wife’s front driver side speaker has failed. I understand the shielding being sold here, but I do not understand how water is able to enter the area. Is it unreasonable to believe this area should be water-tight? I believe that is what needs to be addressed. Although the speaker may be protected, other items in the door remain at risk due to water intrusion.
03-23-2024, 06:51 PM | #35 |
Rep 29
Thanks Friends. Okay I’ll give it a try! And totally agree that it’s quite concerning that enough water is entering the door to destroy a speaker.
@hookson I’ll place the order soon and thanks for the door clips! I’m just arguing with the dealership to help me with the cost since I bought the car three weeks ago and their “inspection” of course found nothing wrong 🙄 -Collin- |
hookson90.50 |
04-06-2024, 06:28 PM | #36 | |
988
Rep 1,806
04-06-2024, 11:21 PM | #37 |
Rep 29
Sad update from me: was finally about to order the two mid range speakers and did a final audio check to confirm both were out (they were). In the process, I discovered that one tweeter in the rear doesn’t work also, and neither of my front tweeters light up (but they emit sound).
This really is going to add up in cost and I am pissed at myself for going to great lengths to buy a car spec’d with B&W. I’m sure it sounds great, but I now see tons of similar complaints of these types of failures. I know the lack of lights and a non working tweeter will also bug me until I fix it…really should have gotten a warranty on this 2019 M5C with a bum radio :-( Anyone else experience tweeter failures? -Collin- |
04-07-2024, 12:33 PM | #38 | |
91
Rep 131
Part number: 65136820713 |
04-10-2024, 08:52 PM | #40 |
91
Rep 131
I will be making some tweaks for the website so it might be down. If you need to order speakers with protective covers you can reach me in DM. Thank you
04-11-2024, 07:42 AM | #41 | |
82
Rep 136
04-16-2024, 10:56 PM | #43 |
Rep 1
hookson Hi, I just got a 540i with the bowers and wilkins and was the first thing I checked when purchasing the car. I have the replacement speakers already but was wondering if I can purchase just the speaker covers from you.
hookson90.50 |
04-16-2024, 10:58 PM | #44 | |
91
Rep 131
Yeah sure you can, shoot me a DM |
