10-11-2023, 07:09 PM | #1 |
91
Rep 133
You might want to check your Bowers & Wilkins
Hello fellow F90 owners!
So apparently I have recently find another widespread issue that affects F90 and G30 equipped with B&W sound system. For those who have it, you will probably agree that its definitely not the best high end stereo (especially compared to B&O) and it can get even worse if you mid speakers will stop playing. And you better check yours, if your car is 2020 and older Circled is the MID frequency speaker. So what happens? Water gets inside the door panel and drips on the open important part of the speaker, such its magnet and wiring. Traces of water and dirt inside the door panel when the speaker is removed. Speaker magnet and wiring is affected by all of this. You can see actual water inside the speaker that was just removed from the car. Overtime, it will damage it and your speaker will stop playing. Car won't get you any codes and it's actually hard to notice sometimes because the speaker will star loosing it sound gradually. The best way to test is to change output to specific side through equalizer. If the speaker is good, you will HEAR IT playing. If in doubt you can compare to rear doors. It mainly happens with the front doors on both sides, however I had a car that required rear ones to be changed as well. Speaker are not cheap at around $200 each and requires door trim removal to be changed and you also need to change all of the door panel clips ones you pulled it. So after some testing I did create special cover that protect pins, magnet and wiring of the speaker. It sits nicely inside the door panel and gives the speaker extra protection from water that drips on it. And it doesn't affect the sound. It sits nicely with the speaker installed and looks OEM. I plan do a repair kit, that will include speaker, door clips, speaker cover at very reasonable price. In the meantime, you can check if your MID speakers are actually working BTW, for whatever reason, it doesn't seem to happen with the cars that are equipped with Harmon & Kardon speakers. Last edited by hookson; 10-11-2023 at 07:43 PM.. |
10-12-2023, 07:30 PM | #2 |
1913
Rep 2,526
I did not notice this on my M5.
2022 F90 M5 Competition & 2019 M2 Competition
2019 F90 M5 Competition 2017 F80 M3 Competition 2014 F10 M5 Competition 2003 E39 M5 |
M3/4/832.50 The5rivers322.50 |
10-20-2023, 10:32 AM | #4 |
69
Rep 92
I read this article about a week ago and found it interesting. Last night as I drove home from work, I noticed that my BW system sounded weak. Most of the sound came from the dashboard speaker and reminded me of this article. I switched the fade to the driver side and sure enough, my speaker is out compared to the passenger and rear doors. The led is still working, but not the speaker.
Can I purchase the special cover? My warranty will cover the speaker but I would like the cover to prevent it from happening again. |
hookson90.50 |
10-20-2023, 02:17 PM | #5 |
1133
Rep 2,334
B&O is terrible, I actually like B&W a lot.
tomgearman34.50 |
10-20-2023, 08:11 PM | #6 | |
91
Rep 133
11-09-2023, 03:30 PM | #7 |
59
Rep 237
Drives: F90 M5, prior F80 M3, E60 M5
This is exactly what seems to be happening to my '19. Just started noticing last week the driver mid stopped working. Then worked for a few days this week and went out again this morning.
I have been testing left and right and definitely the left mid comes and goes. Thanks for the heads up. Let me know when the kit is ready. I thought it was because I had cranked up Floyd's 'comfortably numb' guitar solo too loud. lol |
hookson90.50 Solqmobile6.00 |
11-09-2023, 03:51 PM | #8 | |
91
Rep 133
https://1evel.us/products/bowers-wil...e-door-speaker |
11-09-2023, 05:07 PM | #9 | |
59
Rep 237
Does the door panel need to come off or can the grill just be removed? It looks like from the website link that just the grill can be removed. |
11-09-2023, 05:10 PM | #10 |
172
Rep 221
Just checked my driver side and sure enough it’s out. Am going to see if it’s covered under the cpo, if not I’ll be getting this and the water protector.
11-09-2023, 05:11 PM | #11 |
91
Rep 133
11-10-2023, 12:42 AM | #12 |
IG: @M5RCY_
367
Rep 318
EXACTLY THIS HAPPENED TO ME 2 months ago!
I lost ALLLL mid range sound….even in the rear. My fear was the amp over heated and fried. I drive a 2018 and at 45k miles, luckily I still have extended warranty thru Zuirch. BMW had to replace my amp and all mid range speakers…bill came to $6400. Luckily I paid my $200 deductible and back In business. The front was affected the most. 100% But all my mids were suffering. It sounded horrific.
Autotecknic.com - code: M5RCY for 12% off
Project Gamma - code: M5RCY for 5% off Dura-Coating - code: M5RCY for 20% off |
hookson90.50 |
11-13-2023, 12:21 PM | #14 |
719
Rep 786
This thread is a perfect example of why I love forums. I learned about a problem I didn't even know I have.
So refreshing compared to yet another "What's your M1 and M2 setting?" or "Will this tune screw up my warranty?" thread. Thank you, hookson |
11-14-2023, 06:20 PM | #15 |
68
Rep 69
Yes I noticed it right away I was like why does this system sound weak low and behold front passenger door mid speaker was completely blown and was replaced under warranty on my pre lci 06/2020 m5 comp problem solved..
12-20-2023, 06:33 PM | #18 |
82
Rep 136
Not acceptable in a car at this price point and of course my warranty ran out mid way thru the year. |
12-21-2023, 08:53 AM | #20 | |
5288
Rep 10,686
12-21-2023, 09:09 AM | #21 | |
82
Rep 136
12-21-2023, 10:22 AM | #22 |
989
Rep 1,807
Early failure of catalytic converters is usually a symptom of a problem. Especially when combined with oxygen sensor residue. Why did you feel you needed to add injector cleaner? I would be surprised if that alone would cause damage to the converters unless you was using it very frequently and large amounts.
