BMS Cowl Filters
06-14-2014, 07:31 AM | #1 |
419
Rep 656
BMS Cowl Filters
I found these on N54tuning. they replace the cowl with two small filter that bolt directly over the openings to interior. The claim is that removing the factory cowl allows for better air flow/cooling of the engine bay. Anyone using these?
06-14-2014, 10:00 AM | #2 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
Here they are:
http://www.burgertuning.com/cowl_fil...w_135_335.html Problem I have with them is the removal of the cowling leaves the wiring and hoses that cross the engine hanging loose with nothing to attach them to...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
06-14-2014, 05:45 PM | #3 |
144
Rep 776
There's a couple of threads on these:
http://www.e90post.com/forums/showthread.php?t=889045 http://www.e90post.com/forums/showthread.php?t=897132 http://www.e90post.com/forums/showthread.php?t=779622 |
