06-13-2014, 12:57 AM | #1 |
1398
Rep 5,262
F22 coding cheat sheet
Put together a cheat sheet for the F22....
If you have corrections or additions let me know.... https://docs.google.com/spreadsheets...f=true&sd=true Last update: 6/27/2016 READ IMPORTANT NOTES: 1) NEVER click "Code Default Values" it can reset important stuff and car might not start and need to get towed to the dealer to fix the software 2) Make sure you click "Code FDL" and not "Code" (clicking code will reset the car to the factory setting erasing all the FDL coding for the selected ECU) 3) Always code with the car running or with a commercial grade charger connected to it, else voltage might drop during coding and you could get unexpected errors. (if you are codding the DME ECU you can't have the car running so you will need a charger) 4) Launcher note: E-Sys Launcher Car Series MUST be set to exactly match the car's chassis type you are coding (e.g. F01, F06, F07, F10, F12, F15, F25, F30, F82, F83, etc.). If after install it defaults to F999 and it cannot be changed, change PC Date ahead 4 days, then change E-Sys Launcher Car Series, then change PC Date back to current date. DO NOT create .EST Token and PIN with PC Date advanced 4 days as the Validity Start Date for the token will be 4 days in the future." What's Needed for coding? Enet Cable search on ebay http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40 E-sys software (http://www.bimmerfest.com/forums/sho...d.php?t=983244) E-sys Installation step-by-step BMW - E-Sys Installation Procedure.pdf NEW: Free universal token option http://www.bimmerfest.com/forums/sho...d.php?t=805745 my cheat sheet :-D https://drive.google.com/file/d/0Bwv...ew?usp=sharing NEW e-sys integrated cheatsheet for E-sys launcher 2.4 http://www.2addicts.com/forums/attac...8&d=1444581337 (remove .pdf extension and replace with file on launcher installation folder) NCD CAFD tool http://www.bimmerfest.com/forums/sho...d.php?t=749668 Whatever you do never ever ever press "Code Default Values" ... you have been warned :-) Coding 101 video E-sys Launcher 2.4 Integrated cheatsheet Now you can just tick the checkboxes with the codes you want and they are applied automatically How to VO code Connect => Read FA => Activate FA => Read SVT (VCM) => Right-Click on ECU you want to code i.e. HU_NBT (the ECU itself not the underlying CAFD) => Select CODE. Step by step VO code guide sample for TPMS decoding TPMS VO coding RPA or RFA (Country dependant).pdf Corrupted CAFD Just inject new CAFD into ECU, and VO Code it. Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired ECU => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE. Read I-Level To determine your I-Level, go to VCM Module => VCM Master Tab => click Read under I-Steps List of ECU and CAFD id's to quickly find a specific ECU E-sys_CAFD_ID's_P3.59_v4.pdf Targets: F001 psdzdata covers the F01/F02/F03/F04/F07 (5-Series GT is an F07 NOT an F10) F010 psdzdata covers the F06/F10/F11/F12/F13/F18 F020 psdzdata covers the F20/F21/F22/F23/F30/F31/F32/F33/F34/F35/F36/F45/F80/F82/F83 (There is no Z4 F-chassis yet) F025 psdzdata covers the F15/F16/F25/F26/F48/F85/F86 F056 psdzdata covers the F64/F55 F56 (Cooper Mini's) I001 psdzdata covers the i3/i8 I-Levels 1 - I-Levels Through ISTA-P 3.59.4.pdf Last edited by pikcachu; 09-22-2021 at 06:56 PM.. |
30
siqueiros0.00 doveer10.50 MASHCT541.50 Dav3946.50 SerenVoX145.00 Drpoomanchu307.50 hoyasaxa686.50 SeattleJer6.00 AndrewC198910903.50 ///M Houbi1653.00 DasPanda3.00 KjPerry17.50 koston37.00 boxdotjpeg282.50 vickersss0.00 Resoelg226.00 Kaan810.00 |
06-13-2014, 02:12 AM | #2 |
255
Rep 1,040
Very happy to see you take the time and energy to compile this list for everyone. Again, I just didn't have the time or desire to do so directly. I find a coding feature I have used that is missing I will send it along to be included in your F22 Master list.
06-13-2014, 07:38 AM | #4 |
***** noob
1354
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
Thank you very much
Maybe put a last updated date on the sheet for fyi
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
06-13-2014, 07:39 AM | #5 |
12
Rep 195
Drives: MY14 MG M235i 8-AT
this will come in handy, thanks for taking the time and putting something together!
06-13-2014, 07:42 AM | #6 |
12
Rep 195
06-13-2014, 07:49 AM | #7 |
103
Rep 1,254
Thank you. I get my car this Saturday and was looking to start coding my preferences. I want in my way lol like burger king "have it your way".
06-13-2014, 10:57 AM | #11 |
What goes here?
450
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
Curious about the ENABLE WIFI HOTSPOT entries.. can anyone enlighten?
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
06-13-2014, 11:19 AM | #12 |
1398
Rep 5,262
what i read so far is that it allows connecting devices that suport DLMA to stream to the car.... but seems like you cant use it to share the internet of the car through the wifi
06-13-2014, 11:20 AM | #13 |
1398
Rep 5,262
can read more at http://f10.5post.com/forums/showthread.php?t=809017
06-14-2014, 10:14 PM | #17 |
1398
Rep 5,262
maybe
Xenon brightness Fembody 3050 HELLIGKEIT_FL_BIXENON DRL brightness Fembody 3050 HELLIGKEIT_DRL actually that looks like it's for the F30... can't seem to find it in the F22 cafs Last edited by pikcachu; 06-14-2014 at 10:48 PM.. |
06-15-2014, 10:28 AM | #18 |
Love to Drive
197
Rep 602
Could you please add the coding for the following:
Five blinks when changin lanes Last setting remember auto start stop Last setting remember air conditioning Thanks! JC |
