Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > Gathering my CCC to CIC parts...
      06-11-2014, 11:30 AM   #1
jezzy
jezzy's Avatar
35
Drives: 06 E91 325xi Black Wagon
So, after 3 weeks of owning my 06 325xi wagon, I'm doing the CIC retro. Currently the car is CCC with voice control, no usb, no bluetooth, no telephone.
I just picked up a CIC unit, and waiting for news on a CID.
But, I need the proper cables, and that green connector (unless there's a plug in adaptor I can use to avoid re-pinning connctors?)
I'm keeping my CCC idrive controller (for now).
I've read and read, but can't seem to find a source for the necessary cables.
CID to CIC
CIC to USB ARM REST
CIC to USB GLOVEBOX
CID display connector (that green one?)
thanks!
      06-11-2014, 09:49 PM   #2
jezzy
jezzy's Avatar
35
Nevermind. Ordered it all via ECS tuning (300$ for the needed cables, usb etc..)
Any recommendations on CIC emulators? The ebay ones at all good?
      06-15-2014, 06:02 PM   #3
jezzy
jezzy's Avatar
35
Bought the uk emulator. Looking forward to getting everything!
      06-17-2014, 01:02 PM   #4
PichaDis11
PichaDis11's Avatar
Drives: E90 N52
Hey, would you mind sharing the p/n for cables you bought?
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit
      06-17-2014, 08:39 PM   #5
jezzy
jezzy's Avatar
35
Go to ECS tuning's website.
This is my shopping cart..
USB Adapter Wiring Cable
Used when instaling a usb port
ES#: 2702820
Mfg#: 61129255716
1 $48.93 $48.93
Adapter Cable
Used in CIC system
ES#: 245081
Mfg#: 61119185171
1 $36.99 $36.99
Socket Housing - Pack Of 10
8 pole
ES#: 2607887
Mfg#: 61136954526KT
1 $26.70 $26.70
Universal Pin Terminal Uncoded - Priced Each
4 Pol type. Used in multiple electrical connections.
ES#: 2675906
Mfg#: 61138380696
1 $2.05 $2.05
Radio Trim
Trim that surrounds the radio
ES#: 119249
Mfg#: 51459118703
1 $22.69 $22.69
USB / Auxiliary Input Socket
Provides audio connection to external devices via auxiliary port - Socket only
ES#: 2194689
Mfg#: 84109237653
1 $39.26 $39.26
USB Extension Cable
2330mm (7.6 feet) extension cable from BMW
ES#: 161483
Mfg#: 61119129360
1 $40.57 $40.57
      06-17-2014, 08:40 PM   #6
jezzy
jezzy's Avatar
35
I will have the socket housings qty 9 for sale, the display CIC connector that you'll need for a CCC to CIC.. don't buy one ! I'll gladly sell you one for a few bucks.. they are a minimum buy of 10 units for 26$..
      06-18-2014, 11:53 AM   #7
PichaDis11
PichaDis11's Avatar
Drives: E90 N52
I'll gladly take a few off your hands brother!
      06-18-2014, 06:43 PM   #8
jezzy
jezzy's Avatar
35
No prob. Will advise once I get my order.
Thanks
      06-18-2014, 08:29 PM   #9
jezzy
jezzy's Avatar
35
Guys, what do we need to order for that "usb plate" in the glovebox that holds the USB port in place?
thanks
      06-20-2014, 05:44 PM   #10
jezzy
jezzy's Avatar
35
Does anyone know if I should get bmw to update all my software before doing my retrofit? Seems if I install a oem alarm.. looks like bmw needs to code and update the car. I have a feeling they cant if I've changed to a cic?
      06-21-2014, 08:41 AM   #11
PichaDis11
PichaDis11's Avatar
Drives: E90 N52
You could code the alarm yourself man... far as I know I doubt you'd get much from the update.
      06-21-2014, 07:47 PM   #12
jezzy
jezzy's Avatar
35
I believe it's the dealer coding which is different than the OBD2 port? I'll need a coding expert to chime me in here =)
So far I've gotten all the code, programs, wiring for my items to arrive in the mail. My test coding will be to make my AE's daytime driving lights! =)
      06-24-2014, 01:10 PM   #13
jezzy
jezzy's Avatar
35
Guys below my oem flash light seems to be a spot for a usb.. true?
