2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Radar detector hard wire stopped working
      06-07-2014, 08:04 PM   #1
voyagergab
voyagergab's Avatar
633
Drives: G82 M4 6MT, G01/F97 X3M
Talking Radar detector hard wire stopped working
I have an escort detector hard wired by previous owner in the overhead console of the F10. After 9 months of working fine or stopped working. No power from the connector.
The cig power adaptor works fine.
Is there a fuze somewhere I can check?
Please help
      06-24-2014, 02:11 PM   #2
Julesandtrish
Julesandtrish's Avatar
27
Drives: 335d
2010 BMW 335D  [10.00]
You might need to open the done light area and see if the self tap came loose. Real easy to get off. Search f10 v1 install on YouTube. Good luck!
Enjoy what you drive.
      06-24-2014, 02:13 PM   #3
Julesandtrish
27
Drives: 335d
You might need to open the dome light area and check to see if the self tap connection came loose. Real easy to check for. Search for f10 v1 install on you tube. Good luck!
      06-24-2014, 09:04 PM   #4
voyagergab
voyagergab's Avatar
633
Originally Posted by Julesandtrish View Post
You might need to open the some light area and check to see if the self tap connection came loose. Real easy to check for. Search for f10 v1 install on you tube. Good luck!
Thanks! Just opened the thingy behind the mirror and the radar was tapped into the connector there. The pin became loose.
      07-15-2014, 10:45 AM   #5
virtualbong
virtualbong's Avatar
103
Drives: 2015 BMW X5 MSport
Did I tap the right power wire? On the video it shows a bright green/ brown wire but I do not see that. Is it the red/green wire?
Any help ASAP would be great.
2015 BMW X5 35i M-Sport (White/Brown) - 4/16/18 (Current)
2011 BMW 550i M-Sport (Jet Black/Cinnamon Brown) - 4/30/14 | 2007 BMW 328xi e92 (Jet Black/Coral Red) - PAST | 2005 Infiniti G35 Coupe (Ivory White/Stone) - PAST | 2005 Acura TSX (Obsidian Black/Black) - PAST
| 1998 Acura Integra (Black/Black) - PAST
      07-15-2014, 10:58 AM   #6
virtualbong
103
Pic
5post
