Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > transmision fill question
      06-07-2014, 11:37 AM   #1
gray boy
Drives: 2011 328ix
doing a drain and fill- got a surprise , could only get in 4 qts with engine running,,, thats after the rear of the car was lifted higher that the front
got almost 5 out,, when i checked it with the engine: running, removing the fill plug it appeared to be over filled, it wanted to pour out.
anybody ever seen 4 qts fill the GM tran.??
help
      06-07-2014, 09:57 PM   #2
ryanakata
Drives: '11 e92 335i AT
What was the temp on the drain. What temp on fill?
      06-07-2014, 11:02 PM   #3
Ph0zenstone
Ph0zenstone's Avatar
325
Drives: 2018 530e X-Drive
Should be more...I was able to get a total of 6 qts in
      06-08-2014, 05:51 PM   #4
techie182
48
Drives: 328i coupe
Did 2 weeks ago. Drained 4 Qt and filled 5.5Qt.
