Mod to stiffen chasis/turn in ability
06-06-2014, 02:28 PM | #1 |
36
Rep 148
Pardon if the post is filled with ignorance but I do not know much about the interior mechanics of my BMW.
I recently switched from RFT tires to Non RFT and I'm not a fan of the softer ride. I want something that can stiffen up the ride and make the turn in ability firmer. I know coils and springs are an option but that is out of my budget currently. What I'm lookign for is anything besides that which would stiffen my chaiss/turn in abilities. Thank you! |
06-06-2014, 04:04 PM | #5 |
81
Rep 734
Just savie up and start mod'ing the car slowly, but nothing comes "cheap".
I'll do the M3 control arm swap first. If you're tight on money, do the front first as it is cheaper. Also while you're at it, do the sway bar end links and also have them aligned the front with MAX camber possible. That alone, should make your turn in much sharper. When you have the extra dough, do the rear control arms and things as well, when you're at it, you can also do the m3 subframe bushings which will significantly stiffen up the loose rear end feeling that we get on the 335i. Car will feel much more planted. aftewards. Last thing to consider will be LSD, very pricey mod but will worth every penny. Will help your turning abilitiy by A LOT. car will also feel much more planted and in control during all types of driving. Springs will not help much besides stiffening (ruining) the ride. Coils will be very pricey. I'll leave sway bars till the end. probably do sway and subframe bushing at the same time because you'll have to drop the subframe for the swap (for MUCH MUCH easier access, i actually dont know whether or not it is possible to do it without dropping the subframe).
94' NSX - Garage Queen
97' Integra Type R - Track Warrior (Sold) 01' BMW E39 M5 (Sold), 2x 02' BMW E39 M5 (Sold & sold) 08' E90 M3 6MT - DD 13' W212 E63 AMG Wagon |
06-07-2014, 01:56 AM | #6 |
Rep 42
Swaybars.
Will make the car a lot flatter around corners. Great bang for buck. I had coilovers in my last car, absolutely loved them. Then chucked in swaybars afterwards and fell in love with the way it handled, as I could have the ride fairly plush, yet still retain amazing cornering ability. |
06-07-2014, 07:35 PM | #8 |
164
Rep 2,556
M3 front control arms by TRW and remove the alignment pin from your strut tops and have the car aligned with as much neg camber up front as possible and M3 toe specs. I did this before springs/shocks to improve turn in response lost due to switching to traditional tires.
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS Last edited by cvc 22349a; 06-07-2014 at 08:00 PM.. |
06-08-2014, 07:58 AM | #9 | ||
1254
Rep 4,088
+2 |
06-08-2014, 11:34 AM | #10 | |
37
Rep 257
In the least, I don't really see how this would benefit a car with stock suspension and ride height. If these bumpstops are taller than stock and/or stiffer, how would that benefit handling when you have less shock travel? It would also make the ride more bumpy. I am not talking about modified cars here or when racing them (as I did for 11yrs and we usually cut the bump stops to shorten them). Just stock suspension. But I can see if the aftermarket bump stops are factory length, and they are of harder composition, how it might reduce body roll a little when cornering. Still I don't think it improves handling and might even make it worse or induce understeer. The best mod for body roll is sway bars, and spring/shock combo. If you have excess body roll, dive and squat, then that means it's time for new shocks or look at your rear bushings. Taking down the shocks to just install bump stops is not worth the effort IMO. Might as well replace the shocks and/or springs while at it. Harry
2011 Space Grey 335i xDrive E92, Sport Pack/Premium/Winter/Navi rolling on 342's.
2019 Accord Sport 2.0T 10-sp. |
06-08-2014, 11:55 AM | #12 | |
I got lei'd
845
Rep 7,594
the bumpstops i got from supreme power were like $50 shipped, if you don't like them, return them or sell them I guess, I've driven 2k miles in less than 2 weeks with them, norcal to socal and back twice and never gave me any issues, function or comfort wise. family and kids in the back weren't complaining. I primarily did it to reduce suspension travel when the car would dip on highway dips with a full load of people and luggage and it has not disappointed me at all. I added one half inch rubber bump stop to each corner without any negative drawback IMO. |
06-09-2014, 09:31 PM | #13 | |
287
Rep 595
Your best bet may be to adjust (increase) your tire pressure. I had a blow out and had to temporarily replace one of my non flats with a oem runflat I had lying around. With both rear tires (1 rft 1 nrft) inflated to 35 psi, it was clear exactly where the run flat was. It produced more noise, feel, and response than the regular tire and made the rear end feel funny. To remedy the problem, I left the run flat at 35 psi and inflated the regular tire to 42psi. Problem solved, until I get my new non run flat to replace it. Depending on what runflats you had and what tires you have now, you should be able to replicate the runflat feel and response by increasing the psi of your tires. |
