12-04-2007, 05:57 PM | #1 |
1094
Rep 8,013
Drives: i4M50
Is the Z4M in for a hiding?
I see the new TT/RS is all but confirmed according to some source (Worldcarfans among others) and it looks to be running a 5 cylinder turbo producing as little as 310hp but as much as 350hp. Either amount I reckon will give the Z4M a hard time, especially as it's weight should be roughly 100kgs lighter and with an awd system which saps less power than most.
No date as yet but I see from the video footage else where showing the M3CSL it also shows a new and improved Z4, clearly BMW has this Audi in it's sights and must reckon it's a real threat. Judging by the rest of the cars coming from QuattroGmbH lately that they are right to count it as a threat. Exciting times look to be close by both both brands. |
12-05-2007, 05:00 AM | #2 |
399
Rep 3,288
Is 5 cylinder accurate?
Also, I imagine the new Z5 M roadster will share the e92 M3's V8. Since it has been typical practice for the M roadster to share the M3's engine. At 414bhp, I don't think there is much to worry about. |
12-05-2007, 07:53 AM | #3 | |
1094
Rep 8,013
Drives: i4M50
Sorry, but I do believe BMW should be concerned about a TT/RS. Firstly, if the car comes with 350hp the fact that it's turboed should also mean it will probably have nearly the same amount of torque. Secondly, until BMW chose to use aluminium instead of steel the chances are the new one will gain extra weight and also size so instead of the Z4M's 1495Kgs the new one will more likely weigh 1550kgs, that would probably place it up to 200kgs more and this is more than a 64hp increase can overcome. I don't doubt the BMW will be the more rewarding to drive, it's always been the case but chances are with the TT's weight advantage and stronger torque should mean that the Audi will close this gap by a bigger margin than ever before and could possibly be the quicker of the two. Also, in the past BMW has always seen the Z cars as driver's old school experience cars and that why no SMG, if the new one follows suit that will give it a disadvantage as the TT/RS will almost certainly come with DSG and might have 7 gears. So you can see that I reckon BMW are more than just a little concerned by the thought of a TT/RS. |
12-05-2007, 11:06 AM | #4 |
2070
Rep 4,365
Drives: '07 Z4 Coupe, '21 X3, '16 GMC
I agree, I don't see any TT as a real threat in performace. For comfortable driving you can get a TT but for real performance the Z4M will still come out on top.
2007 Z4 3.0si Coupe • 6 MT • Black Saphire Metallic • PP • SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4 2017 Harley StreetGlide • Denim Black • V&H Tune 2021 BMW x30i • Phytonic Blue Metallic • Fully loaded |
12-05-2007, 11:12 AM | #5 |
My favorite sign.
167
Rep 4,333
It still looks like VW beetle
A 5 cylinder engine would be a first...
12-05-2007, 11:19 AM | #6 |
2070
Rep 4,365
I have seen inline 5 cylinder engines in an SUV before...
12-05-2007, 01:57 PM | #9 |
213
Rep 3,834
Drives: Jerez E90 M3
Volvos have had 5 cylinder cars for the longest time.
11' E90 M3 6MT | Jerez Black | Black Ext./Carbon | ZCP | ZCW | ZPP | ZTP | 302 | 403 | 507 | 5AC | 655 | 6FL | 752 |
15' F80 M3 6MT | Black Saphire | Black Full | ZEC | ZLP | 2VF | 2VZ | 5DL | 688 | |
12-05-2007, 02:47 PM | #10 |
1094
Rep 8,013
Drives: i4M50
It's not an inline 5 cylinder, it's a Vee 5.
12-05-2007, 07:27 PM | #11 | ||
399
Rep 3,288
From http://www.worldcarfans.com/6061121....ore-audi-tt-rs
From http://www.topspeed.com/cars/audi/20...s-ar15071.html Quote:
12-05-2007, 07:30 PM | #12 |
517
Rep 18,858
I hate to say it, but I do think that the Z4 (even the Z4M) could use a boost in power. Even if the Z4 were to get the tt3.0 from the 335, that would be a drastic improvement...
12-05-2007, 07:45 PM | #14 |
My favorite sign.
167
Rep 4,333
Not necessarily. It's a lot easier for it to resonate, since it's unbalanced, but there are ways around it. Even so, the cost of modal research to fix it would probably make it unworth it. I doubt an unbalanced cylinder alingment like that makes any significan't performance increase anyway.
12-06-2007, 01:16 PM | #15 |
213
Rep 3,834
Your right, your Z4M wont be an ounce lighter than your Z4M. I say it will be about the same...
12-06-2007, 01:19 PM | #16 |
60
Rep 2,128
12-06-2007, 01:59 PM | #17 |
1094
Rep 8,013
Drives: i4M50
Does it really matter if the engine is a vee or inline or even if it's got 5 or 6 cylinders, surely the most important thing is the output and the torque, if this TT/RS has 350hp and similar torquw from a turbo unit it will surely best the Z4M in acceleration based on it should be at least 140kgs lighter.
As for the rest of it, the DSG 7sp gearbox, well this has been talked about for a while now but as of yet no solid evidence has appeared. The reason why I believe some of the reports are true about it being a 5 cylinder is the weight, this engine in 2.5L form should be lighter than a high-revving 3.6L v6 and that will aid it's handling. Something that Audi seems to be trying very hard to get recognition for and two example of this hard effort can be seen in the RS4 and R8 so why would they fall backwards and produce a dog in the form of the TT/RS. No, I reckon the TT/RS will be a better handling and performing car than the Z4M in much the same way as the RS4 did compared to the E46 M3 when it was launched. |
12-06-2007, 03:05 PM | #19 |
213
Rep 3,834
12-06-2007, 03:51 PM | #20 |
29
Rep 1,002
