Help needed to locate the x11003 connector?
06-05-2014, 06:47 AM | #1 |
Rep 28
Hi
I have a 2005 e90 and i am the in process of retrofitting cic into it i did not have satnav previously, i wanted to know if anybody knew which one of these is the x11003 connector so i can connect the controller power wire to it? Ive been told i should connect it to pin 3 if 2005 - 2007 models, does that mean there should be a wire already in pin 3 or do i have to buy a pin and wire from bmw to put in the pin 3 slot and if so does anyone have the part number for the pin and wire from bmw? Thanks for help in advance. |
06-06-2014, 09:15 AM | #2 |
2810
Rep 5,316
Drives: G80 M3 6MT
I THINK its the blue one. But I would look at WDS to double check. I think you can find the info there
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
06-06-2014, 04:48 PM | #3 |
17
Rep 55
The blue connector is correct.
According to the wds for MY 2005-2007 it is Pin 3 on the x11003. Pin number 3 should NOT be used by something else, therefore you have to add the pinhead yourself. I think this is the partnumber for the pinhead: 61131378906 http://www.realoem.com/bmw/showparts...62&hg=61&fg=20 scroll Down to x11003, and check part jumber. Remember to add the fuse, 5 amp on FUSE 13 (verify with your fuse Card) best regards! |
