N52 has iron cylinder sleeves?
12-04-2007, 07:24 AM | #1 |
3572
Rep 10,352
I was having a discussion with another BMW fan who drives a Z3, and he asked me of the new engines had iron cylinder sleeves. His opinion was that aluminium block engines w/out iron cylinders sleeves do NOT do well after ~100k miles.
Thoughts? |
12-04-2007, 08:46 AM | #2 |
11
Rep 194
I think BMW knows a thing or two about engines NTW
06 330i gry/blk everything but iWreck, nav & pdc
carbon splitters, door trim, grill, roof spoiler CDV delete, B&M Short shifter, cyba scoops |
12-04-2007, 08:51 AM | #3 |
11
Rep 194
In the North American market, the inline-4 engine was complemented by a larger straight-6 engine in 1997: the 2.8 L M52B28. This engine, similar to the BMW M52 in the 328i except with an all aluminum block and head, was especially desirable with its 189 hp
12-04-2007, 08:55 AM | #4 | |
111
Rep 1,772
The N52 doesn't have iron sleeves, but it does have a hard, low-friction ceramic coating over the alumium cylinder surface. In case you aren't aware, modern sportbikes rev to 14,000 - 16,000 rpm (depending on engine size and model) and last easily over 100,000 km. They run cyliner coatings of a similar type to our BMWs. Cylinder wear won't likely be a problem in these N52 and N54 engines. |
12-04-2007, 09:33 AM | #5 | |
3572
Rep 10,352
Thanks! |
12-04-2007, 10:51 AM | #6 |
111
Rep 1,772
of course it would have issues without the coating! It is an iron ring rubbing an aluminum cylinder!
12-04-2007, 01:19 PM | #7 |
67
Rep 527
We've had alusil lined cylinders in the V8's for over 10 years. The early V8's had issues with the nikasil coating and the fuel in the states, but most of those short blocks were replaced with alusil blocks and lasted as long or longer than a regular cast iron sleeve.
The guy is talking out his ass.............and he drives a Z3.
10 AW on fox E90 M3 with 2 pedals, gentleman’s ride
08 AW on fox E92 M3 also 2 pedals, a bit more rowdy |
12-04-2007, 01:36 PM | #8 | |
111
Rep 1,772
It is not the new hard-ceramic coating that I was discussing above. |
12-04-2007, 01:49 PM | #9 | |
3572
Rep 10,352
I didn't think the N52 had iron, so I was concerned with what they would have used as a substitue if any (couldn't imagine they didn't). Remember, BMW considers 100k as lifetime of the car. |
12-04-2007, 03:26 PM | #10 | |
111
Rep 1,772
12-10-2007, 10:14 AM | #12 |
87
Rep 1,555
Correct
