AC Doesn't work when it's hot out?!?!?!
06-03-2014, 08:36 AM | #1 |
31
Rep 339
A few days ago my AC appeared to suddenly stop working. I am relatively familiar with the common components that could fail and have searched through the forums to try and find a duplicate scenario. The problem that I have is that the next morning, I got in my car and the AC worked...
I have found that ~75 degrees is the tipping point. If the ambient temperature is below 75, then my AC is bone chilling cold. If the ambient temperature is above 75, then my AC blows hot air... Any thoughts on what is causing this? Is there a thermometer or sensor somewhere that might have failed to cause this? I am scheduled to see the dealer tomorrow for an oil change and will have them look at it, but I want to figure it out as much as possible before I go in. |
06-03-2014, 11:04 AM | #3 | |
31
Rep 339
6/6/14 - Hasn't leaked since being cycled and the problem was not fixed, it was just cool enough outside when it was cycled to be unable to duplicate the problem. Has everyone baffled now. Last edited by SP3333D; 06-06-2014 at 01:06 PM.. |
06-06-2014, 10:07 AM | #4 |
31
Rep 339
So a little follow up. Had the system cycled, ran cool for a day (granted that it was under 75 degrees out that day) now it is back to doing what it was doing. Had 2 shops verify that it still has the right amount of R134 in it and there are no leaks... Headed into the dealership Monday to try and figure it out...
06-06-2014, 11:24 AM | #5 |
89
Rep 3,732
Drives: BMW S1000XR
Keep us updated. I had the same problem...one BMW dealer said "cannot duplicate customer concerns". In all fairness this was their response to every concern The 2nd dealer recharged my AC and all is well again, but they could not find any leaks or problems either.
BMWCCA member |
06-06-2014, 01:01 PM | #8 |
31
Rep 339
This is where I am putting my money. I haven't seen any diagrams on this setup, but I know that a lot of systems have a sensor on the compressor that fails and causes the AC to stop all together. It is the fact that it still works sometimes and is not a total failure that seems to have everyone baffled.
06-06-2014, 01:12 PM | #10 |
483
Rep 681
Maybe a dumb suggestion/question, but you do have the dial on the center stack moved to the blue/cold side correct? If not that will affect temps from the a/c.
06-06-2014, 02:30 PM | #12 | |
31
Rep 339
I had given this some thought too, I understand that there may even be a thermostat of sort on there that could be shutting it down. I am trying to get some spec sheets and the applicable service bulletins to verify. |
06-06-2014, 09:15 PM | #13 |
435
Rep 686
Drives: 06 330xi (TRADED IN)
Switching over from a line of non-Euro cars, this threw me off transitioning from AC to heater... "How the hell is it blowing rather cool air when I have the frickin' heat turned all the way up?"
06-10-2014, 02:12 PM | #14 |
31
Rep 339
Soooooooo, after 4 hours of diagnostic, the dealer determined that the compressor is shot, but still barely functional. They explained that it appears to be overheating due to some type of failure and it is shutting down when it gets too hot. The car could keep it cool enough on colder days, but not on hotter days, so the AC became ambient temperature dependent.
I ordered a new Denso compressor yesterday from Amazon for $340 with next day shipping and they got it this morning. The dealer quoted $1,440 for the BMW part plus 3.7 hours of labor. The quote was for roughly $1800 I will update this with whether or not that that did the trick once I get it back(Hopefully tomorrow!!) |
06-10-2014, 04:00 PM | #15 |
Rep 57
Another thing to think about, is the color of your dash and whether or not you're using a sun shade. I found, with my black interior, that the dash would get way hot and when the AC was on, it was blowing warm air. Turns out, this is due to the dash "absorbing" all of the cool air or warming the air on the way out. After the dash would cool down, so would the air coming out of the vents. I've started putting a sun shade in whenever I park and it's made a world of difference.
Also, your A/C can only do so much, I believe they say it can only cool the ambient air down by 20-30*F. So if it's 100 degrees out, you may very well only be getting 80* temps out of your vents because that's all the A/C unit can do. Just a thought/tip! |
06-10-2014, 06:22 PM | #17 | |
douchebaggo
186
Rep 972
06-10-2014, 06:44 PM | #18 |
35
Rep 1,652
Drives: '10 AW/CR e92 6mt 335i
bump to remove spam from top
COBB AP Stg 2+ FMIC Aggressive | VRSF 3" Catless DP | COBB FMIC | BMS DCI | CP-e Metal Charge Pipe | 370+ whp/435+ lb.ft torque
06-10-2014, 11:42 PM | #19 | ||
31
Rep 339
this should take you to the one that I bought. (I paid $332 +$8 overnight shipping) http://www.amazon.com/dp/B004SG323E/..._6X9Ltb07ZPAT4 this model number ends in 1529, I believe the other compressor was the same model number, but ends in 1532. they got the compressor this morning, 18 hours from ordering to delivery (I love amazon), but ended up having to order new bolts and have to wait until Thursday to get it put back together. I will update as soon as I get it back! Last edited by SP3333D; 06-12-2014 at 08:35 AM.. |
06-10-2014, 11:46 PM | #20 | |
31
Rep 339
06-11-2014, 11:38 AM | #21 | |
Rep 23
06-12-2014, 05:18 PM | #22 |
31
Rep 339
Day 4 at the dealer, got all of the necessary parts in and they started taking it apart yesterday and broke the aluminum bolts holding the part on. They got new bolts this morning and went to to finish the job, spent all day extracting the old bolts and then finishing the install. Then as they were putting it back together, the top radiator hose broke... Now we have wait until tomorrow for a new one to come in and finish the installation...
