F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Musicar PnP DSP amp upgrades for 676 HiFi F30
Studio RSR
      06-01-2014, 10:48 PM   #1
VP Electricity
VP Electricity's Avatar
Drives: F34 xDrive
We recently have been validating a multichannel amp/processor in a HiFi F30 sedan.
It's rated at 55 watts per channel into 4 ohms and 70 watts per channel into 2 ohms. That means into a HiFi system, it will have 55x4 front and rear and 70 by two into the underseat woofers.
It has 30 bands of parametric EQ per channel. It has time correction per channel. It has output level controls per channel in 1dB increments, and it has 24dB crossover filtering built in.
It also has outputs for a sub amp, so we can pair it with a 300W or 500W mono sub amp and our F30 OE-Look enclosure if you like.
So, we have finally locked down our F30 tune. It blows away HK in terms of clarity, staging, and detail. It has a HiFi PnP harness prewired to it, and it's premounted to our F30 amp plate. You run our power harness to the battery, and you now have instantly fine-tuned sound.
You can retain the center if you like. Our testing definitely sounds better without it. We use a dedicated 2-Pin Molex quick disconnect so you can decide for yourself which is better. We think you'll agree that center channels are a commie plot.
We are offering the following packages (EMAIL us for details and pricing, please don't PM):
- PnP 380W DSP amp, prepped and programmed
- PnP DSP amp and 300W sub amp, with the DSP set to band-pass the underseat 8", and the DSP also tuning the output to the sub in the OE-Look enclosure.
- PnP DSP amp, 500W sub amp, and upgraded trunk sub driver in the OE-Look trunk sub.
These are not available for RHD cars, for base Stereo cars, or for HK cars at this time, sorry.
      06-02-2014, 12:15 AM   #2
VP Electricity
Drives: F34 xDrive
In response to some questions, I need to clarify - this upgrade isn't as high in performance as our Level One kit, but it's a startling improvement to a HiFi car without replacing any of the speakers, so the total cost of the upgrade installed is materially lower.
      06-02-2014, 10:00 AM   #3
Fronzdan
Drives: '24 M240 xDrive
What is the pricing? Couldn't find it anywhere on the site.
      06-02-2014, 03:34 PM   #4
VP Electricity
Drives: F34 xDrive
It's not on the site. http://musicarnw.com/contact-us/
      06-02-2014, 09:11 PM   #5
blackf30n55
Drives: 2014 335i Msport
Soooo. How much?
      06-12-2014, 11:02 PM   #6
cdgatti
cdgatti's Avatar
255
Drives: e90 328i
Are you using the Prima?
OEM Black grill and Blackline tails - LCI halogens with Lux V2 coded as DRL - 3M Crystalline - BMS PBX - OEM Euro Airbox with K&N - Hardwired CTEK - Bilstein B6 w/OEM springs and SP perches - Conti DWS06 - HiFi-Helix DSP - JLAudio HD/XD-Morel - CD changer trim - AE optical out
      06-13-2014, 05:48 AM   #7
Technic
Technic's Avatar
2306
Drives: 2021 i3S, 2024 i4 M50
Power output stated looks like the Helix/Match unit.
      01-25-2015, 11:19 PM   #8
obriennathaniel
@obriennathaniel_f30 on Instagram
obriennathaniel's Avatar
Drives: 582whp/596wtq '13 335i
Is the DSP/amp still available? and does it work well with the BAVsound setup?
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge|
      01-26-2015, 05:22 AM   #9
bri1042
bri1042's Avatar
5976
Drives: 2021 IOMG M3 6MT
It should be, and it does. Email them from their website.
      01-27-2015, 08:46 PM   #10
paul223
paul223's Avatar
Drives: F10
I think it is match pp82dsp, which is great unit.
f30post
