Help with these fault codes?
06-01-2014, 07:36 AM | #1 |
187
Rep 1,247
I have a UK 330d LCI with the N57 engine.
As I have the N57; INPA can't give specifics on the fault codes. I have the following which I believe are due to my Combox retrofit: KOMBI A554 60 MASK/CCC E1CF 20 The first I believe is due the fact that the SOS feature now doesn't work. My research on the second looks like a change of configuration to the original specification. I then have: JBBF A6D1 21 which I believe is an auxiliary water pump issue. JBBF A6CF 68 which is an AUC sensor fault. Finally I have DME/DDE 494A 61 which I believe is a glow plug fault. My thoughts are I can cure the top two with some sort of coding, the water pump issue I'm not sure, I can buy an AUC sensor for not much and the DDE issue maybe a glow pug control unit. Thoughts? |
