I have a small triangle with a black exclamation point in it above my MPG dash displa
05-28-2014, 10:31 PM | #1 |
Wildwestrider
10
Rep 78
On the digital display between the tach and speedo,...I have a tiny red triangle with a black exclamation point in the middle. It's just above the "M" in "MPG". Can anyone tell me what this is?
Brian in Austin |
05-28-2014, 10:44 PM | #4 |
35
Rep 1,652
Drives: '10 AW/CR e92 6mt 335i
Go into iDrive or the scroll toggle on your turn signal and press the stalk in when you see it say "Check Control" and it will tell you what it means. If you're checking through iDrive its under Menu -> Vehicle Status -> Check Control. It could be anything.
Shit Idk if its the same for '06 330i's. |
05-28-2014, 10:58 PM | #6 |
8
Rep 263
Drives: E46, E91, F21
You probably have a service due.
05-29-2014, 08:09 AM | #10 |
Fuck it dude, let's go bowling.
888
Rep 2,480
I think it may be BMW's troll alert, but not 100% sure. Check to see if it's also showing up in your Land Rover and Benz. Report back.
You so funny!
1M. Previously: '13 135is; '07 E90 335i; '02 325i; '99 Z3; '98 328is; '87 L6; '77 320i
05-29-2014, 08:35 AM | #12 |
26
Rep 551
I was going to say the exact thing this morning. Only 3 posts and all 3 have been borderline trollish. I'm just on stand by waiting for his next, epic thread.
05-29-2014, 08:58 AM | #13 |
I'll get back to you
7564
Rep 2,132
Black ! bad!! If it was red or yellow or orange then you'd be OK.
2018 Stinger GT
2009 E90 N51 /Active Autowerke Stage 2 tune/BMW Performance Exhaust/ Countermeasure enthusiast. |
05-29-2014, 09:10 AM | #14 | |
54
Rep 484
ZURICH posted a PDF that explains what the symbols mean http://www.e90post.com/forums/showthread.php?t=611567
Yours is on page 19 and means: Quote:
2007 328xi E92 6MT Jet Black/Coral Red | Tracks: NJMP
05-29-2014, 09:14 AM | #15 |
Let's roll...
Rep 166
According to my searches it indicates that the sensors have detected a loose nut behind the wheel. I wouldn't recommend driving it. I have seen this before and it can lead to serious injury or worse.
JK, in all seriousness, it is most likely just letting you know that you have a service that is due. If you have the owners manual you can find the section that deals with this and it will walk you through the process of determining which service it is. If you do not have the owners manual you can go to the official BMW site and download the owners manual for your car and do the same. |
05-29-2014, 09:20 AM | #16 |
71
Rep 628
Drives: ...when not replacing gaskets
Give the guy a break. At least his sentences are readable.
05-29-2014, 09:50 AM | #17 |
295
Rep 2,202
This little triangle comes up for whatever slight reason that something needs your attention. It comes on for issues low on gas, tire pressure low, light bulb out, speed limit exceeded etc... You still need to read the manual though.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
05-29-2014, 12:08 PM | #18 |
35
Rep 1,652
Didn't even notice it was bcolins. He asked about if vynil wrap exists or something? OK yeah I think troll too. Lol
05-29-2014, 12:16 PM | #19 |
26
Rep 551
05-29-2014, 05:23 PM | #20 | |
Libertarian
132
Rep 1,577
But yet, you've heard of vynil records... Vynil is the new vinyl.
2011 335xi Coupe BSM (e92/N55/ZPP/ZCW, Alpina B3 Flash)
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k |
05-29-2014, 06:00 PM | #21 |
197
Rep 3,211
