So I slid her around the turns
05-27-2014, 08:16 PM | #1 |
109
Rep 1,062
And not it doesn't seem to turn/corner as well. Did about 7 or 8 slides. First slides ever, not sure they were the best implemented slides. What could've loosened her up
Specs are 07 E92 335i 36k KW V3 coilovers and front is lowered 2 inches, the back only an inch. Last edited by ThatRWD; 05-27-2014 at 08:33 PM.. |
05-27-2014, 08:26 PM | #3 |
255
Rep 2,547
Great story, tell it at parties.
05-27-2014, 08:31 PM | #6 |
109
Rep 1,062
Errr I gotta start explaining my self using full sentences, have this problem at work too often and it already had the KW V3s on there prior to the slides. On a side not I drove my neighbors 328xi for a good 70 miles the other day god the stock suspension is horrible.
Editing op. |
05-27-2014, 08:42 PM | #9 |
26
Rep 551
05-27-2014, 08:45 PM | #10 |
448
Rep 668
Drives: 2011 AW E90 M3
05-27-2014, 08:45 PM | #11 |
141
Rep 1,423
Drives: '07 N54 e90, '10 N54 e93, TBSS
LSD would make it easier to control.
E90 - H&R Touring - M3 Front Arms - Work Genosis GS-1 19x9+30 x10+26 225f 265r stretch - AA FMIC - AR DP - Cobb E30 Map +160rwhp/+200rwtq
E93 - Style 95 - RB Turbo - AR DP - Evolution RW FMIC - PTF E50 +242rwhp/+234rwtq |
05-27-2014, 08:50 PM | #12 |
nsomneeak
39
Rep 501
Relevant:
RB Turbos w/ N20 TMAP Sensor | 93 Octane Protune by Cobb Plano | xHP Stage 3 | BMS DCI | STETT CP | Forge DVs | RB PCV | Helix FMIC | CP-E Catted DPs | Walbro 450 | Bilstein B12 | M3 Control Arms | Defiv Lockdown Kit | BBS CH | Michelin A/S 3+ Hixson BMW of Monroe, LA - Shady Dealer | |
05-27-2014, 08:52 PM | #13 |
109
Rep 1,062
No I'm saying ever since the sliding I did, in regular Prius people turns the car doesn't feel as planted and it seems to tilt as lot more. I could 20MPH turns before and the car would still feel like its fair well planted and flat but now it feels like its slanted and it tosses me to the side...
05-27-2014, 08:54 PM | #14 |
236
Rep 1,037
Maybe you messed up your alignment, I'd have that checked first. Take it to a reputable suspension shop to have them look at it.
M340i: Arctic White, 790M wheels, Cognac interior, Aluminum Tetragon trim - Totaled
05-27-2014, 08:57 PM | #16 | |
40
Rep 823
Drives: 2008 335i Coupe TIAG
05-27-2014, 09:08 PM | #17 |
109
Rep 1,062
They're not sharp 90 degree turns, and no I don't do anything risky near people. Or on my car for that matter, figured it could've taken some slides. Traction control doesn't even kick on and normally I'm going with the flow of traffic while making these turns.
05-27-2014, 09:10 PM | #18 |
109
Rep 1,062
But if you can call the grocery store yesterday you will have your milk today right That video was too good.
05-27-2014, 09:19 PM | #19 |
255
Rep 2,547
I'd sell it and get a new m3.
05-27-2014, 09:33 PM | #21 | |
39
Rep 315
Also, lowering springs stiffen the ride so around the corners the car is more stable but this means less weight is on the outside tires which will cause it to slide more too (Oversteer instead of understeer). Stiffer springs and suspension CAN actually hurt handling on rough/bumpy roads. Is the car understeering or oversteering? Understeering means the car is turning less than the wheels - aka plowing. Oversteering means the car is turning more than the wheel is turned - aka drifting.
07 335i
Mods: JB4 + MHD BEF, RB Twos Plus, Phoenix PI Manifold, Dual Walbro 450 LPFP's, DCI, VRSF DP's, VRSF 7.5" FMIC, VRSF CP + TiAL BOV, VRSF inlets & aluminum outlets, TC Kline SA, M3 F/R control arms, M3 subframe bushings |
05-27-2014, 10:16 PM | #22 | |
426
Rep 2,136
