Transmission Oil Change at 80K?
05-27-2014, 02:14 PM | #1 |
7
Rep 166
I'm currently at about 78K miles and have not done a transmission oil change. From what I've read on the forums and talking to a couple of friends, you either do it at 50-60K or you don't do it at all.
At about 50K the dealer did "top up" the transmission box and fixed a leak. What do you guys think? Should I go ahead and replace it? A garage quoted me $800 bucks for the job the other day... OR I can buy a BMW PE Exhaust |
05-27-2014, 02:57 PM | #2 |
16
Rep 301
Probably best just to leave it. I find when vehicles start getting older sometimes it's the gunk that builds up that keeps everything sealed up tight.
If you were flushing it regularly since new, then by all means. But if it's running okay, and you've never drained or flushed it... I'd just leave it alone. |
05-27-2014, 03:04 PM | #3 | |
Curmudgeon and Pedant
690
Rep 3,489
Change it now. |
05-27-2014, 06:19 PM | #4 |
Rep 89
You can test the fluid with the paper towel test. (Im assuming BM fluid is pink/red when new/clean), like most fluidds). Take a clean piece of paper towel, drop 1 drop of old fluid on it. Wait for 5 minutes. If the drop expands out to size of a quarter, it is still good. Also, color should be pink/red, not brown/coffee.
Should also not smell "burnt". I would never own an AT, but that much I know about fluid. An AT needs good fluid to work. It can destry your AT if not in good condition to behave like it should in the AT case. good luck, man. |
05-27-2014, 06:29 PM | #6 | |
1086
Rep 1,912
This is correct. BMW's definition of "lifetime" is 100k miles. That is too long an interval for most people so it is recommended that you change it every 60-80k. I change mine every 80k and am on the original transmission at 212k miles. Last edited by PINeely; 05-27-2014 at 09:36 PM.. |
05-28-2014, 03:34 AM | #7 | |
7
Rep 166
Alright, I'll do it then, thanks guys. Does $800 sound reasonable for the job? |
05-28-2014, 07:38 AM | #9 | |
7
Rep 166
Did you buy the set yourself or did they have it in stock? |
05-28-2014, 08:45 AM | #10 | |
690
Rep 3,489
1) Drain, remove pan, replace filter and replace pan gasket, fill with ~4-5 quarts. 2) Above, but also use a pump to replace the ~2 quarts that are in the torque converter. If you don't do that you're only replacing 3/4 of the fluid. $800 is a little pricey for 2). $350 is about right for 1). Make sure you know which is being done. |
05-31-2014, 08:11 PM | #11 | |
The Law
64
Rep 391
I had a transmission leak when my E90 was under warranty and the issue was the mechatronics sleeve, this might be the problem.
2006 Alpine ,325xi sedan,Terra, steptronic,Xenon,heated seats,Premium package
05-31-2014, 11:08 PM | #12 | |
81
Rep 734
I got my own oil, watch the guy did it and he charged me only for labour
94' NSX - Garage Queen
97' Integra Type R - Track Warrior (Sold) 01' BMW E39 M5 (Sold), 2x 02' BMW E39 M5 (Sold & sold) 08' E90 M3 6MT - DD 13' W212 E63 AMG Wagon |
06-01-2014, 07:08 AM | #13 |
1903
Rep 6,968
Drives: 2007 Black/Black 335i e90
You can do it yourself for under $200.00, as long as you have the right tools.
All you need is the pan/filter and some fresh fluid. You can use Amsoil or Redline. Amsoil sells their 10qt jug for about $85.00 if you are a member. The Pan/ Filter can be purchased for around $100.00 on Amazon. Just check the part numbers and make sure. I would say at 80K it would not hurt. I think it should be done every 50K in my opinion. BMW's lifetime filter really translates to 100k and done. If you have not, you should flush the power steering fluid. You dont need to use petosin. I used Amsoil ATF. I just flushed it several times really good. I asked techs at Amsoil if I could do this and they said their product would work with no problems. That was 15k ago. No problems. |
06-01-2014, 12:28 PM | #14 |
7
Rep 166
They're changing the filter / pan as well. But I felt it was a bit over the top. Think that's what I'm going to do, get the oil myself.
06-01-2014, 01:35 PM | #15 |
Rep 132
I just changed mine today and the old fluid was very dark. The fluid new is a golden color. I would change it if I were you. You can do it yourself easy, heck if I didn't live a million miles form any members I'd say bring it over here and we could knock it out in 30 minutes or so.
2011 335i Coupe M Sport: Alpine White
06-02-2014, 12:52 PM | #16 | |
7
Rep 166
06-02-2014, 01:46 PM | #17 |
Rep 132
ZF Lifeguard6 purchased off of eBay for much cheaper than anywhere else.
Also I did not have an 8mm hex wrench for the fill plug, but a 5/16 is the exact same size, which my toolset had.
06-02-2014, 02:01 PM | #18 |
11
Rep 176
Im also interested in doing the same thing. My car is at 75k miles rigght now. Can you give some periodic feedback about what your driving experience has been like after the change. Any problems, or unusual changes in the operation of the transmission.
BTW i was advised by dealer not to change b/c its lifetime oil, but then again I am iffy. |
06-02-2014, 02:07 PM | #19 |
690
Rep 3,489
06-05-2014, 08:53 AM | #20 |
7
Rep 166
Got it changed (finally!). Found someone to do the job for a much more reasonable price as well: $380.
The oil that came out was pretty dark and the stench was disgusting. Felt like the car was bleeding out toxins. I think the warm climate accelerated the breakdown a bit. Anyway, it got changed with fresh ZF fluid and installed a new filter too. Shifts are smoother now, hopefully no permanent damage has been done. I'll keep you posted. |
06-05-2014, 12:26 PM | #21 | |
81
Rep 734
