2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack TPM, this correct?
      05-26-2014, 01:57 PM   #1
KroLeXz
31
Drives: 2018 BMW M3
TPM, this correct?
Temperature seems high and Im not entirely sure these are the right PSI.
http://i28.photobucket.com/albums/c2...pszpl7la4a.jpg
      05-26-2014, 01:58 PM   #2
KroLeXz
31
Drives: 2018 BMW M3
Forgot to attach image
      05-27-2014, 07:15 AM   #3
th1rd3y3
Drives: '20 M340i xDrive
Were you driving the car? The temp will go up if you were. Otherwise, for pressures, there's one easy way to tell if the readout is accurate. Check it manually.
      05-27-2014, 09:37 AM   #4
KroLeXz
31
Drives: 2018 BMW M3
I was driving, spirited.
      05-27-2014, 10:26 AM   #5
th1rd3y3
So yeah then it makes sense why your front tires are that much warmer than the rears. Turning increases friction, friction increases heat.
      05-27-2014, 01:52 PM   #6
Delnari
Delnari's Avatar
Drives: 2014 MG F22 Auto
Pressure too high in the front should be between 32-34 psi when warmed up. You are getting excessive heat from too high pressure which causes the rubber to wear more quickly. I typically get under 105 degrees on the fronts even when driving hard. You rears should be below 40 psi also.
      06-06-2014, 02:51 PM   #7
tccox
tccox's Avatar
Drives: 2014 228i Msport
Question. Is your display showing the actual tire pressure numbers because you have the tech package? My non tech package does not show actual numbers
A peasant and proud of it
Save The Manuals!!!
      06-06-2014, 04:51 PM   #8
Oyinko
40
Drives: M235i
You have to code this feature in the USA. By default you don't see temp or pressure.
2addicts
