2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Tire pressure for 19" 245/40/19 Run flats?
      05-24-2014, 04:42 PM   #1
irogkj
Drives: 528I Xdrive 2012
Just swapped out OEM 17" wheels on my 2012 528I Xdrive to 351 M Sport 245/40/19 tires and wheels (non staggered). I know I can look at the suggested pressures near the door but since this was a modification, wondering what pressures you would recommend for the new tires?
      05-24-2014, 04:49 PM   #2
613Bimmer
613Bimmer's Avatar
106
Drives: One car with good steering ;)
look at the stickey at the top of the menu. Have fun with those rims, i hope you like them. Just a tip, by the way, if youncould buy non runflats for your car after the current ones wear out.
Good luck OP😊
      05-24-2014, 08:19 PM   #3
irogkj
Good luck OP��
Thanks but the sticky above does not mention tire pressure on the 245/40/19's. Why the recs against run flats? Not sure I really want to carry a spare in the trunk and just went 35,000 on my prior run flats?
      05-26-2014, 09:37 AM   #4
613Bimmer
613Bimmer's Avatar
106
It will significantly improve the ride quality of the car as well as the handling ability. There's a reason why the M5 doesn't come with RFTs. Sorry about the misinformation before.
Good luck!
      06-01-2014, 10:47 PM   #5
snj1013
87
Drives: 2011 528i
35psi would be a good starting point.
5post
