Gas nozzle keeps prematurely shutting off
05-23-2014, 12:05 PM | #1 |
352
Rep 2,050
Hello guys. I'm having this annoying issue where when I'm pumping gas the nozzle keeps clicking off as if my tank is full, I pretty much have to keep pressing it down over and over again until my tank is full. Went to the dealer and they told my the charcoal filter went bad so they replaced it and I haven't had any problems until 3 months later it's starting to come back but not as bad. My warranty is up so I don't think they will help me out but I'll try to see if the dealer can repair it since it's reoccurring. Does anyone know or heard of this issue and what else can go wrong? Will if effect my car long term ? Thanks
05-23-2014, 12:11 PM | #3 |
Libertarian
132
Rep 1,577
I fill up at the same gas station about 2-3 times a week.
Pump 3 is my normal pump, but if it's being used, I go to pump 1. Pump 1 does the same thing you are describing. Pump 3 does not. It has something to do with the nozzle, probably not your car.
2011 335xi Coupe BSM (e92/N55/ZPP/ZCW, Alpina B3 Flash)
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k |
05-23-2014, 12:15 PM | #5 |
9
Rep 120
I have the same occurence, but only at Costco. It will always prematurely topoff, but if I go to Chevron or 76 or Shell, it will fill up normally.
05-23-2014, 12:23 PM | #6 | |
354
Rep 3,036
Drives: BMW/MERCEDES/PORSCHE
I was just about to post this, I always have problems at Costco, never anywhere else
BMW E93 M3 / Mercedes Benz W209 CLK500
BMW E64 650I(sold) / BMW E92 328I(sold) / BMW E46 M3(sold) / BMW E92 335I(sold) Porsche 996 911 C2(sold) / BMW E46 325CI(totaled) |
05-23-2014, 12:39 PM | #7 |
52
Rep 393
my nozzle prematurely shuts off too...usually the result of too much whiskey
2011 335i e92
JB4 Stage 2, VRSF chargepipe, VRSF downpipe, Hankook Ventus V12 evo2s |
8
05-23-2014, 12:46 PM | #8 |
Libertarian
132
Rep 1,577
I was wondering how long it would be before someone made the joke. I was holding off... ahem. So to speak.
05-23-2014, 12:48 PM | #9 |
1705
Rep 14,829
It happens in many places with my 335i. Because we have full serve only, I get nervous when the attendant turns the nozzle upside down, it may fall out and hit the 1/4 panel.
05-23-2014, 12:55 PM | #11 |
Life is better with burnouts
97
Rep 611
Drives: BMW
I repair gas pumps and their components at gas stations. Usually the car is at fault for this type of thing happening not the gas dispenser handle. But broken handles do go overlooked, so tell the attendant at the convenient store if it keeps happening. No fully inserting the handle into the car sometimes helps. Let me know if you have anymore questions. Also NEVER TOP OFF YOUR GAS TANK.
StradaRedlands4943.00 PR3C1510N63.50 |
05-23-2014, 01:10 PM | #12 |
need4speed
510
Rep 1,903
Same thing happens to me. I live in SoCal as well. I think it either do to the amount of pressure in the tank (weather conditions etc), how the E9x gas tube is angled (part the gas cap goes onto. Can't think of the name) or how much our gas pumps get used since we live in CA and there's sooo many cars. I don't experience this problem at every pump but I'd say about 1/3 of the time I experience this problem. It's not just you OP
N54
05-23-2014, 01:41 PM | #13 |
352
Rep 2,050
Pretty much every gas station I goto has the same problem. I always used to blame the pump but I fill up my e46 and my wife's Lexus and never have issues.
I'm taking it to the dealer. I heard of something called "tank rebreather valve" I notice whenever the nozzle shuts off it's because the tank it over filling. Once the fuel gets drained into the tank I can continue filling up but it's very annoying |
05-23-2014, 01:43 PM | #14 |
352
Rep 2,050
So does flipping the nozzle upside down help people? For me it's an issue of the fuel slowly draining into the tank so no matter what position I try it still clicks off
05-23-2014, 01:47 PM | #15 |
Macgyver
208
Rep 942
Possibly your refueling vent hose seen in item 16, is blocked or kinked.
GTX3076R , ADV, JB4, FMIC, BOV, 17"APEX, 255/40/17 SQ, 6-SPD Manual
05-23-2014, 02:28 PM | #17 |
10
Rep 87
Drives: SGM E92 335i
When I first got my car, I went to a Shell right after and filled up with no problems. My second tank of gas came from Mobil and for whatever reason, the nozzle kept kicking as if it was full. Never had that issue anywhere else, so it's most likely just the nozzle.
05-23-2014, 02:33 PM | #18 |
Libertarian
132
Rep 1,577
Yeah, makes no sense why this would cause a problem. I might not top it off right to the filler hole, but the downtube is mostly full... Never had a problem.
05-23-2014, 03:03 PM | #19 |
55
Rep 474
Drives: 2009 328I E90
Huuuge no no, if you study your evap system, you will see that when you top you tank off there is a chance that you send gas into your charcoal canister, which kills the canister and its not a cheap piece, plus if you get gas in there, it literally gets thrown right out of the car onto the floor....
//// M3 Conversion front bumper //// Csl trunk lid //// mtech rear bumper //// resonator delete //// airrex digital air suspension //// megan camber arms //// godspeed toe arms //// Stance Wheels sf01 19x8.5 / 19x9.5 ////
instagram: thebernardexperience |
lab_rat394.50 |
05-23-2014, 03:20 PM | #20 |
55
Rep 474
When the pump switches of, im done filling up. No if, ands, or buts! I take the nozzle out, 2 taps on the filler neck so that i get the last drop to in the tank rather than on my quarter panel, then i hang the nozzle and get some candy from the gas station... or a redbull
05-24-2014, 12:25 AM | #21 | |
352
Rep 2,050
05-24-2014, 08:11 AM | #22 |
Master Gunner
77
Rep 435
Drives: 2008 335i Sport
This for me since Costco is typically up to 10 cents cheaper per gallon than anything close. But I never have problems at the same Costco with my 2010 F-150 nor when I had my E46.
2008 335i Alpine White Sport Sedan AT | Avant Garde M364 Staggered 19"
