Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > What if you don't drive it much?
      05-22-2014, 03:32 PM   #1
SSW
I Can't Drive 55
SSW's Avatar
Drives: 2008 BMW 335i (E90)
So, I've only owned my 335i since Dec and after I finished upgrading and fixing it up last month, I haven't been driving it much.
Started it up last week for a short drive and the "date" in the iDrive system disappeared and had to re-enter it. Started it up again today and this time not only did the date disappear but I also got a check control code warning (the small triangle w/the ! in the middle) and the BC symbol w/the "car up on the lift" which directs you to do a "vehicle check" BUT I didn't get the trouble code # (if there was one) before the check control triangle and vehicle check symbol went away.
Just wondering: Is it common to lose the date and get control codes if you don't drive your 335i much?
2008 Black Sapphire 335i E90 Sport & Premium Pkgs - Cobb Stage 1+FMIC Sport map, Mishimoto FMIC & Alpina B3 AT Flash. See: My Build Thread.
      05-22-2014, 03:38 PM   #2
e92_enthusiast_1
e92_enthusiast_1's Avatar
Drives: '10 AW/CR e92 6mt 335i
2010 BMW 335i  [0.00]
Sounds like low battery. Just drive it around a bit so it can recharge. Might be close to replacement time. Read these batteries last like 5/6 years.
COBB AP Stg 2+ FMIC Aggressive | VRSF 3" Catless DP | COBB FMIC | BMS DCI | CP-e Metal Charge Pipe | 370+ whp/435+ lb.ft torque
      05-22-2014, 04:06 PM   #3
SSW
I Can't Drive 55
SSW's Avatar
Thanks for the response.
Thought it might be the battery but, after all the $ I've thrown at this car, I certainly don't want to have to buy a new battery too (especially if I've got to bring the car into a shop to get the system re-coded to "register" the new battery).
So, I'm just going to hook up a Battery Tender to see if this solves the problem.
      05-22-2014, 04:10 PM   #4
e92_enthusiast_1
Yeah my dealer wanted an exorbitant amount just to replace it. Something like $500. I was like pfft no way. I did end up buying a cable and software to do it myself. I didn't have a laptop but I found a tiny older one on ebay for $75 so its solely used for car diagnosis now.
      05-23-2014, 06:27 PM   #5
SSW
I Can't Drive 55
SSW's Avatar
Just attached one of these motorcycle type connectors from one of my Battery Tenders (I've got 4 of them) to the battery posts in my E90.
This makes it possible to charge the battery w/o having to remove the battery cover and connect clips to the posts every time I want/need to hook up the Battery Tender.
      05-23-2014, 06:30 PM   #6
boris
Борис
boris's Avatar
Drives: e92 n54 335i
Sounds like the symptoms I had when my battery was on it's way out.
If you still have the OEM battery, you can see that its got a little clear plastic hole in the top of it. Theres a color chart right next to it.
Those things weigh a ton though.
07 SG 335i GONE!
COBB - Burger Motorsports -Ultimate Racing - Evolution Racewerks - TiAL- AMS
In Winter Mode - Dunlop Wintersport 3D/Sport Edition Wheels
      05-23-2014, 07:07 PM   #7
SSW
I Can't Drive 55
SSW's Avatar
Don't know what it looked like before but, after being on the Battery Tender overnight, the color in the ring is green -- dark green and hard to see, but green nonetheless.
      05-23-2014, 07:10 PM   #8
AWDBooSTIn90
Nomore
AWDBooSTIn90's Avatar
Drives: 335i Coupe 6MT N54
Is it common to replace with oem? I seen regular batteries at sears that were listed to fit.
Do you use inpa to register the new battery?
      05-23-2014, 07:16 PM   #9
e92_enthusiast_1
Regular batteries are fine (just make sure if you need AGM you get AGM) and yes register it. INPA works there are others too.
      05-23-2014, 11:13 PM   #10
tm6030
54
Drives: Bmw 335i 2009
Same thing happened to me when I parked my car for the winter. Happened twice after the day I took it off parking. Go on a 45 mintue cruise and it will be fixed. Didnt happen again after the cruise.
      05-27-2014, 10:17 AM   #11
SSW
I Can't Drive 55
SSW's Avatar
After being on the Battery Tender for a couple of days, the color indicator on the battery in my E90 changed to BRIGHT green -- much easier to see. So, the battery must have been in a very low state of charge before, because the color was previously a very dark green -- much closer to black, which would indicate low/no charge.
Going to keep the E90 on the Battery Tender 24/7 from now on to avoid further problems until the battery actually goes belly up. That makes 4 vehicles that I have on Battery Tenders 24/7. The F250, MR2, Concours and the Beemer. Just too many vehicles and not enough time to drive them all.
The only vehicle that's not on a Battery Tender is my FJ. It's my daily driver for errands around town and trips into the City (SF) . It's the only vehicle that I park on the street BUT I have a side yard that I can park it in, where I can hook up a Battery Tender to it if need be.
      05-27-2014, 10:35 AM   #12
e92_enthusiast_1
Nice nice. Thx for following up.
      05-27-2014, 04:34 PM   #13
bobkat09
bobkat09's Avatar
152
Drives: 2023 M240i RWD
What kind of cable did you buy ? and where did you buy it from? I'm having trouble finding quality cable that works on my 09.
      05-27-2014, 05:12 PM   #14
e92_enthusiast_1
It was off of eBay. I don't remember exactly. I can search my order history if you want. It even came with a DVD with INPA. I think I just searched for BMW INPA on eBay and tons of stuff comes up.
      05-27-2014, 05:14 PM   #15
bobkat09
bobkat09's Avatar
152
Thanks man...I'll check it out.
