Had headlight error codes turned off now have engine codes
05-21-2014, 04:48 PM | #1 |
10
Rep 66
Just had Okee turn off my headlight codes but now funny thing is I have a check engine light. I tried to clear the codes and clear the adaptions with BMW logger and it does clear but then I restart the car and they come back. Not sure what to do with this. Here are the codes. The car idles and drive perfect.
2CFB,1,Throttle-valve adaptation value 2D09,4,Throttle valve |
05-21-2014, 05:09 PM | #2 | |
35
Rep 1,652
Drives: '10 AW/CR e92 6mt 335i
It might just be coincidence. Im not sure what a throttle valve is. If you google the codes does anything from e90post.com show up?
COBB AP Stg 2+ FMIC Aggressive | VRSF 3" Catless DP | COBB FMIC | BMS DCI | CP-e Metal Charge Pipe | 370+ whp/435+ lb.ft torque
05-21-2014, 05:21 PM | #3 |
8
Rep 263
Drives: E46, E91, F21
Try clearing the codes again. Then turing off the ignition. Then turn the ignition back on, engine off. Let it wait there for a while. (I usually have a charger hooked up.) However for arguments sake more than a minute, although I have had to leave the car sitting for more than 30 mins in the past. Turn off ignition after, then see if the check light is on or if you can rev past 3000rpm. Hopefully this is all you need.
05-21-2014, 05:26 PM | #4 | |
10
Rep 66
05-21-2014, 05:49 PM | #5 | |
8
Rep 263
turn on ignition, engine off fully step on gas pedal wait 5-10 seconds off gas pedal wait about 1-2mins turn off ignition Start vehicle once. then shut off. Then start again. see if the check engine light is on. if it is then you may have a faulty TB. However it is hard to say, as i am diagnosing through a computer screen. Sorry dude. |
05-21-2014, 05:54 PM | #6 | |
10
Rep 66
05-21-2014, 06:05 PM | #7 | |
8
Rep 263
05-21-2014, 08:40 PM | #8 |
10
Rep 66
well have an update. I cleared the codes again and turned the key off and removd it. Put the key back in and hit the start button but not starting it. All dash lights were on. Just left it on without starting it and went in the house for 15min. Came back out and removed key and let it set just a bit. Put the key back in and fired it up. No more check engine light and all is back to normal. Before just after it started it would throw the light. Now if I cleared the codes while running it would stay clear till I done a restart. But have been driving it with many restarts and still no light or code. It was like adaption for the startup was lost or something.
05-21-2014, 08:43 PM | #9 |
2812
Rep 5,316
Drives: G80 M3 6MT
Its a known issue with the BMWLogger adaptations reset that you will get a throttle body error and you need to perform the reset.
It even say so on their website!
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
05-21-2014, 08:48 PM | #10 |
10
Rep 66
05-21-2014, 09:06 PM | #11 |
2812
Rep 5,316
Drives: G80 M3 6MT
Yes you did it right
Scott, Partner
05-21-2014, 09:10 PM | #12 |
10
Rep 66
05-21-2014, 09:56 PM | #13 |
8
Rep 263
Good to hear that your car is happy again
06-22-2014, 09:02 PM | #15 |
Came to the N55 Darkside
1115
Rep 12,740
That's really surprising- Okee is a pretty damn good coder, and a stand up guy.
Why didn't you text him when you had the issue so he could've cleared it remotely and helped you out? Did he make mention of any possibility that what you experienced was a direct result of coding? |
06-23-2014, 01:09 AM | #16 | |
10
Rep 66
06-23-2014, 01:11 AM | #17 |
10
Rep 66
06-23-2014, 04:34 AM | #18 | ||
1115
Rep 12,740
