Wanted: N54 BMS Intakes, Charge Pipe & DV's/BOV
05-20-2014, 05:28 PM | #1 |
111
Rep 1,487
My car is a little highly strung now not to have these so, before I buy new, I wondered what was out there
Cheers |
05-21-2014, 04:08 AM | #2 |
96
Rep 2,204
Best to buy new mate - especially the CP.
I recommend the ER CP very robust piece of kit!! Also add BMS OCC if you haven't got one - it's a must. Finally source Forge DV's which you can get in UK - although OEM DV's are up to the task (depends on your boost level). Mine were fine until I went 18psi and above then I went Forge ! HTH
Engine Mods: VF HEX Stage 2, ER Charge Pipes, VRSF Catless Downpipes, BMS Intakes and PCW Exhaust Mod
Running Gear Mods: HRE Flow Form F01, Yellow Stuff pads. Cosmetic: Performance Grill, Lip Spoiler, Splitters, Side Skirt Extensions, Diffuser and BMS Tips |
