AC evaporator drain location
05-18-2014, 09:39 PM | #1 |
43
Rep 335
Anyone knows how e90 evaporator drain pipe can be located? I did search this forum and the web overall. There's a bunch of topics on this matter but none answers this question.
I suspect mine is blocked to some extent and this leads to some unpleasant smell. I think drainage is very important to our AC systems, 'cause I believe once you either turn AC off or turn the engine off some lid blocks AC evap. to prevent windshield fogging. You can hear this lid working as well as airflow redirect. Because of this useful and convenient feature, evaporator's ventilation is very limited and not in your control. Drainage is very critical. I tried to inspect underbody as much as I could, but with no results. Most is covered by plastic panels, and whatever is not covered, is related to exhaust. I doubt they would locate the plastic/rubber piping next to source of heat. There should be some water under the car after AC usage, but I do not see this under mine car, and, honestly, can't remember if I ever saw this. |
05-18-2014, 09:42 PM | #2 |
2810
Rep 5,316
Drives: G80 M3 6MT
Mine drains in the front center of the car (around where the gear selector knob would be on the inside)
If the unpleasant smell is only when you first turn on the AC for a few seconds then thats normal.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
05-18-2014, 11:34 PM | #3 |
43
Rep 335
ok, I just found some service info (not in english) which states, that the system has drain holes in the area of gear box tunnel. This might explain.... I was looking for some sort of a hose/pipe, but it might be the case when no hose exists....
05-19-2014, 05:33 AM | #4 |
17315
Rep 18,737
The evaporator drain is on the right side (passenger side) of the trans tunnel about halfway up. It has a rubber flap on the end to keep bugs from nesting in the tube. The end is right about at the end of the transmission where the driveshaft connects. Marked in pic below.
05-19-2014, 04:34 PM | #5 | |
40
Rep 823
Drives: 2008 335i Coupe TIAG
05-19-2014, 04:59 PM | #6 | |
35
Rep 1,652
Drives: '10 AW/CR e92 6mt 335i
Man i wish i had a lift like that lol. Lucky, is it yours? or just random pic?
COBB AP Stg 2+ FMIC Aggressive | VRSF 3" Catless DP | COBB FMIC | BMS DCI | CP-e Metal Charge Pipe | 370+ whp/435+ lb.ft torque
05-19-2014, 05:31 PM | #7 | |
43
Rep 335
05-19-2014, 05:53 PM | #8 | |
194
Rep 310
Wow! Nice lift.
Kudos on the garage setup... Quote:
05-19-2014, 05:59 PM | #9 |
52
Rep 393
sorry to thread jack but can you tell me why this is norma? dealer told me the same thing
2011 335i e92
JB4 Stage 2, VRSF chargepipe, VRSF downpipe, Hankook Ventus V12 evo2s |
05-19-2014, 06:48 PM | #10 |
2810
Rep 5,316
Drives: G80 M3 6MT
Has something to do with the leftover water not draining and it get hot and causes the smell... something like that. Its honestly very technical and one of the things I just didn't fully understand.
Scott, Partner
05-19-2014, 08:10 PM | #11 |
17315
Rep 18,737
05-20-2014, 09:04 AM | #12 | |
1007
Rep 2,108
One way to fight this is to turn off the A/C a few minutes before your trip is about to end, but keep the fan running. This will dry the ducts, reduce the bacteria/mold growth and keep the smell low. |
uncoturner5.00 tomgwuyn26.00 |
05-20-2014, 10:29 AM | #13 |
Curmudgeon and Pedant
690
Rep 3,489
This. Also, you should manually turn the hvac system to OUTSIDE AIR (unless it's more humid outside than inside - read SE US) which often helps dry the system, especially in the dry SW.
05-20-2014, 11:04 AM | #14 | |
43
Rep 335
05-20-2014, 03:07 PM | #15 | |
1007
Rep 2,108
Edited: Checked the user manual, can't find it. I must have read it somewhere else then. I had been doing this, I don't have smell issues. If your drain is clogged, you will get that water coming out somewhere, most probably on the passenger feet well area. I had a Miata which had its A/C drain clogged, it did that. Water won't disappear by itself, it will come out of somewhere if it can't come out of the drain. Last edited by PhaseP; 05-20-2014 at 03:20 PM.. |
05-22-2014, 09:10 PM | #16 |
43
Rep 335
Ok, I found it. Here's how it looks like. The image done by some sort of web cam I bought at amazon, so the quality is poor, but that was the only way I could get there.
First image - the pipe is closed. Second, - I slightly opened the cap using some rod I mounted with web cam. Third image - this device I built in order to get to the pipe somehow. Fourth - the place I inserted the device. Camera is looking towards front of the car. The access was very limited. My car has sport package, and its ground clearance is only 5". I don't think one can get to this pipe without getting under the car. My pipe didn't look like it was blocked, I'll use some cleaner to eliminate the smell. P.S. Red mark on the last image - the area of water discharge, - around the edge of the plastic cover. Last edited by accel; 05-22-2014 at 09:15 PM.. |
05-17-2019, 08:19 PM | #17 | |
236
Rep 481
05-17-2019, 08:55 PM | #18 |
2124
Rep 2,758
This thread might be of some use to you guys. I plan on doing this in the next few weeks. https://www.e90post.com/forums/showthread.php?t=1075529
