Walnut blast and resetting adaptations
05-16-2014, 09:02 AM | #1 |
11
Rep 204
I recently had my 335i walnut blasted at 156,xxx miles. Believe it or not, even though it looked bad, it wasn't as bad as I'd expected. I also replaced all the plugs myself the same day before getting the media blast. The car ran awesome...for one day. The next day, the car had rough idle of about 700 and it felt like it was misfiring. I have JB4 and didn't get any misfire codes or SES light. I took the car back to the shop and a tech took it for a drive...he got about a block away a got limp mode. Misfire cylinder 2 code was pulled. Plug was pulled and inspected...no problem. Coil was replaced with a known working one...still same problem. Tech thought it may be an injector and suggested I bring it back the next day for further diagnostics. Before I left, I reset adaptations with the JB4 and the rough idle immediately went away. I drove off to work and several times, I floored it past step down mode, revved to redline, and waited...no misfire codes or SES light. When I got off work, I got her on the highway and did several WOT pulls on map 5 and still, no misfires or SES light. Has anyone experienced anything similar? Am I in the clear, or should I still be worried about the injector?
05-16-2014, 10:23 AM | #2 |
58
Rep 665
I've done a walnut blasting twice and I never had to reset adaptations. You may have a flakey injector or maybe there was a partial clog which cleared itself. I'd put a bottle of Techron in a half-empty tank just in case and not worry about it unless it happens again.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
2016 Jaguar F-Type S AWD - Polar White/Cirrus |
