05-12-2014, 11:59 AM | #1 |
82
Rep 398
searched and no luck. please help on sending text on idrive
ok I searched for the answer to my question but seems like I have problem finding it. so here we go..
I have samsung galaxy s3 (soon to be s5). After I connected Via BT, it started getting texts no problem. However, when I try to reply, below recipient, there is a line saying "dictate text" and my phone name greyed out below that. Anyways I go to dictate text and it shows "dragon drive" and I need to register. So, seems like once I register I have to pay for the dragon drive? Is that the only way to text someone via idrive? I don't even know how to text while stationary. Could anyone give me steps to text someone from the screen where you put in recipient? Not only for me, I think this thread will help those who are confused at this if someone can give step by step instruction while 1.stationary 2. while moving. Thank you so much in advance. I do have BMW apps etc btw if you wanted to know. |
05-12-2014, 12:17 PM | #2 |
9
Rep 113
You can either sign up for Dragon Drive (no clue how much -- I never could figure it out from their horrible website) or if your phone has S-Voice (Siri on iPhones) then you just hold the talk button down and dictate a text using your phone instead. Siri/S-Voice integration only works on MY2014 the F3x unless you've had your car coded to enable the feature.
05-12-2014, 12:28 PM | #3 | |
33
Rep 326
05-12-2014, 12:32 PM | #4 | |
82
Rep 398
also how do I send a text while not moving? |
05-12-2014, 01:15 PM | #5 |
15
Rep 242
Note, the first thing you need to do is google "replace s voice with google now" and change the settings on your phone to use google now otherwise none of this will work.
05-12-2014, 04:31 PM | #8 |
309
Rep 1,748
05-13-2014, 03:22 AM | #9 |
82
Rep 398
05-13-2014, 03:39 AM | #10 |
15
Rep 242
Ok - now I have a keyboard, some information for you....
First off, Google NOW is what you want - you wont be able to do anything flash with the Samsung s-voice stuff. Plenty of posts on how to disable S-voice and replace it with Google NOW if you do some searching on google. With Google now, you can voice dictate with your phone - press the red button and say "text joe blogs and say lend me some money" - Google now will look up the name, and will send a text (with a confirmation of "about to send text to joe bloggs of ...."). In your car, the Google now works the same - but here is the thing.... when you press the voice button on your car, you are speaking to your CAR. Do a long press on the voice control when your phone is connected by BT, and you will be speaking to your phone, and you can say the standard google now commands including "send text to ...." etc) - your phones responses will show up on your cars screen. The only headache you may have, depending on your phone, is that if your phone screen is off, the voice command may talk to google voice dial instead of google now - but this is easily sorted. |
05-13-2014, 02:32 PM | #11 | |
82
Rep 398
Havent tried yet since i wanted to wait for someone to answer this for me. I will definitely try. Thank you again! |
05-13-2014, 04:14 PM | #12 |
1577
Rep 3,888
How does one enable Google Now over Bluetooth on 2013 NBT? Would one need to upgrade firmware as well as enable via coding? Is there anyone doing this as a service? Thanks.
05-13-2014, 05:07 PM | #13 |
62
Rep 891
Drives: 2023 X5M Comp
Anyone know if something similar is for the iPhone?
2013 535ix
05-15-2014, 10:04 PM | #14 | |
BimmerPost Supporting Vendor
665
Rep 1,980
Drives: 2020 G20 320i M Sport
I would say if you received a software update from the dealer after September 2013, you should be good to have it coded.
CMB Solutions Limited |codemybimmer.ca
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
