SIB 11 03 14 BMW diesel walnut blasting
05-09-2014, 03:16 PM | #1 |
3575
Rep 10,355
Creating a thread so search engines will pick it up.
05-09-2014, 03:24 PM | #3 | |
411
Rep 3,049
Drives: 2009 BMW 335d
05-10-2014, 11:28 AM | #6 |
23
Rep 294
Drives: 335D
Hooraaay! my bet paid off for purchasing extended warranty haha. Agreeing on the Sticky!
05-10-2014, 05:22 PM | #9 |
411
Rep 3,049
05-11-2014, 07:13 AM | #11 |
BMW Advanced Diesel, 2011 BMW 335d M sport...
87
Rep 783
Why would this be covered under warranty, it just showing how they clean it says nothing about honoring CBU cleaning with the warranty...
BMW Advanced Diesel, 2011 335d M sport...
05-11-2014, 07:30 AM | #12 |
155
Rep 253
As I read it,CBU removal is a warranty covered service if it can be shown to be affecting vehicle function e.g throwing codes such as those shown. It doesn't seem to me that this is covered under warranty as a preventive measure to be performed as routine service.
2023 M3
2022 X7 2018 430i 2016 328i |
05-11-2014, 07:50 AM | #13 | |
87
Rep 783
05-11-2014, 09:11 AM | #14 | |
Rep 11
"WARRANTY INFORMATION Covered under the terms of the BMW New Vehicle/SAV Limited Warranty or the BMW Certified Pre-Owned Program." |
05-11-2014, 11:19 AM | #15 |
23
Rep 294
Drives: 335D
05-11-2014, 01:56 PM | #17 |
87
Rep 783
good question, I bought mine private and bought extended warranty through BMW...
05-11-2014, 03:54 PM | #18 | |
23
Rep 294
Drives: 335D
Says Cylinder head, intake, gaskets and such. If not, time to cause a storm at BMW when the time comes. |
05-11-2014, 04:44 PM | #19 | |
87
Rep 783
10-01-2015, 11:17 PM | #20 |
Rep 155
Major issue with this service
Hi all,
I recently picked up a 2009 335d and am having a local shop perform this cleaning due to some error codes I was getting that pointed to carbon buildup. Turns out, the motor had a ton of build up and this is a service it definitely needed. However, after a day of working on the car the shop informed me they didn't have the tool to lock the crankshaft hub / advance the pistons/valves to TDC. They said it'd be an extra day or two - totally understandable. Then I was called to come in to the shop to give them "advice" on how to move forward. Apparently the build up in one cylinder was really bad and when they pulled the glow plug out debris somehow fell "under the piston" and are inside the cylinder. They said maybe I had a bent rod that caused this. I can't imagine the car running well when I took it in (outside the error codes you wouldn't know there were any issues). They said they can try to clean as best they can but can't be 100% sure there's no debris trapped under the piston and the only way to know for sure would be to pull the head. My question: Is this due to not advancing the pistons/valves to TDC before cleaning each cylinder? Is it possible for this to happen if the TSB at the top of this article was followed? That's the way I see it, but before I ask them these questions I want to make sure I'm correct and not pointing fingers. They seem like good guys that know diesels better than most local shops and I don't want to try and get out of a bill that I should pay. I also don't want to pay another $3k to pull the head if a corner was cut earlier and I shouldn't be in this situation in the first place. Any thoughts? This is my first diesel and I'm not as familiar with them as I'd like to be. |
10-02-2015, 12:26 AM | #21 |
Rep 14
Valve not Piston
I think you mean under the valve, not under the piston.
You are absolutely correct. The procedure of rotating the engine ensures that the intake valves are closed prior to blasting each cylinders intake. You start at cylinder 1 at TDC, perform the cleaning for that cylinder, then rotate to the next cylinder, repeat, etc. If the procedure is followed there is no way that walnut shells or anything else can get past the valves and into the cylinder. I don't understand why they pulled the glow plugs, as they are not part of the procedure, nor affected since they are not in the intake. If they pulled the glow plugs, the only thing that could drop off the glow plug is the element that heats up, which would be very obviously broken off once the glow plug was removed. It sounds to me, and this is pure speculation, that they might not have covered the other intakes while they were blasting the one at TDC and accidentally dropped something that fell into an uncovered intake that had an open valve, again pure speculation. There is at least one video on YouTube that shows the carbon blasting process, watch it to familiarize yourself with the process. Perhaps they rotated the engine before ensuring all the walnut shells were vacuumed out. As soon as the valve opened, the shells would have dropped into the cylinder, on top of the piston. With the intake off the engine should rotate relatively easily by hand. Last edited by nwsnowboarder; 10-02-2015 at 06:19 AM.. Reason: Added glow plug info after re-reading prior post |
