Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > >>> Bimmer Retrofit: Presents iClick Technology, new approach in BMW retrofits! <<<
      05-07-2014, 07:33 PM   #1
bmwretrofit
bmwretrofit's Avatar
194
Drives: BMW
iClick Technology
A new approach in BMW coding and retrofitting
Bimmer Retrofit is proud to present an absolutely new type of coding process which is already implemented in all of our Retrofit Adapters (eNBT Retrofit Adapter, activation modules, rear-view camera modules, PDC modules and more). iClick technology is a new concept in BMW world, which allows to instantly enable and disable various features or options using iDrive controller. It is very easy to use and does not require any technical knowledge. This information will be useful to anyone who is considering doing a BMW retrofit (CIC navigation system, NBT navigation system, rear-view camera, PDC or others).
Introduction
iClick Technology is a new type of coding process which is now included in all of our Retrofit Adapters by default. Simple combination of iDrive controller turns and clicks can enable or disable various coding options instantly. This new iClick Ttechnology removes the need of coding knowledge, coding specialists and remote coding. Most importantly, the new iClick Technology removes the need of extra expenses after visits to the BMW dealer (which can wipe out the coding that was previously done).
How iClick Technology Works
Retrofit Adapter has a built-in logic which allows the user to perform configuration of the vehicle using the iDrive controller. Clock on the monitor is used for results output and for interaction during the configuration process.
This configuration mode is called iClick Mode. To begin configuration, user must switch the Retrofit Adapter to the iClick Mode by pressing the 'MENU' button and holding it for ~7 seconds, and then selecting the desired coding option/feature by entering a 3 digit code, associated with the desired option/feature. A list of all available options/features and associated 3 digit codes are provided in the next section (this list is constantly updated. Latest list can be obtained from Bimmer Retrofit at info@bimmerretrofit.com - specify your name, date of purchase and invoice number).
While holding the 'MENU' button down, keep an eye on the clock on the monitor. As soon as you see time '0:00', that means you have entered the iClick Mode.
The next step is to select the desired option, by entering the associated 3-digit code, in much the same way as you select a code on a combination lock.
For example, your desired option is 'Factory Default Settings'. The associated 3-digid code is 4-3-4. You will need to rotate the iDrive controller to the "RIGHT-LEFT-RIGHT" to change the value of the clock from 0:00 to 4:34.
And that’s all it takes to enable/disable or activate the desired feature!
Available 3-digit configuration codes for the Retrofit Modules (as of 05/01/2014*)
Service modes:
4-3-3 Firmware Update Mode
5-5-4 PNP Module Reboot
5-5-1 Self Coding Mode
4-3-4 Factory Default Settings
4-3-5 Send current settings to USB VCOM
Operation modes:
5-1-1 Nav and Voice Activation
5-1-2 Video in Motion activation
5-1-3 Manual camera controls via iDrive controller
5-1-4 Block CAN ID:3AF from PDC to CIC
Vehicle specific modes: (Only one vehicle specific mode can be selected per time)
5-2-1 PDC Conversion for E7x series (pre-LCI only)
5-2-2 PDC and RFK for E7x series (pre-LCI with factory RFK camera only)
5-2-3 E8x/E9x Rear View Camera for Automatic Transmission with PDC option
5-2-4 E8x/E9x Rear View Camera for Automatic Transmission with no-PDC option
5-2-5 E7x pre_LCI Rear View Camera for Automatic Transmission with no-PDC option
5-3-1 E7x LCI Rear View Camera based on Reverse Light
5-3-2 E7x LCI Rear View Camera based on Shifter position
5-3-3 E8x/E9x Rear View Camera for Manual Transmission with no-PDC option
5-3-4 E6x Rear View Camera for Automatic Transmission
5-3-5 E6x Rear View Camera for Automatic Transmission based on Reverse Light
5-4-1 E6x Rear View Camera for Manual Transmission
Firmware Update - Mode used to update firmware in the Camera Module. Detailed description of the update process is provided at the end of this document
Factory Default Settings - set all settings to factory defaults
PNP Module Reboot - reboots internal processor of the PNP module
Send current settings to USB VCOM - sends current settings in to VCOM USB port. Please note that you should have USB cable connected to your computer and some terminal emulation software running. Port settings: 115200 8N1.
Nav and Voice Activation - activates or deactivates Navigation and Voice activation in PNP module
Video in Motion activation - turns ‘ON’ or ‘OFF’ video in motion speed signal filter in the PNP module
Manual camera controls via iDrive controller - Allows camera to be turned on or off by iDrive controller. This option is always ‘ON’ by default.
Block CAN ID:3AF from PDC to CIC - required only for new models of vehicles
Vehicle specific modes - refers to the model of the vehicle where camera is installed. Mode should be selected after camera is installed. After vehicle mode is selected you can perform camera coding to the headunit. Simply choose the mode which is more suitable for your vehicle and its model. Camera may function correctly in more than one mode, this is normal.
Check out our website: http://bimmerretrofit.com/store/inde...y&path=157_160
Download official brochure at the bottom of this post!
Watch iClick Technology in Action:
      05-28-2014, 04:16 PM   #2
tooshay
tooshay's Avatar
Drives: G20+M3 badge
When will this be available?
G20 with some ///M3 stuff = G80
      05-28-2014, 09:54 PM   #3
bmwretrofit
194
Drives: BMW
This is already available and is included in all of our activation modules and eNBT Retrofit Adapter by default!
      11-18-2014, 03:38 PM   #4
Itec
Itec's Avatar
Drives: E92
Where can I read about eNBT Retrofit Adapter? Someone here posted that NBT is available for E-series? I don't see any information about it...
      11-25-2014, 01:17 PM   #5
bmwretrofit
194
Drives: BMW
There are a few resources that you can read:
NBT Navigation System Retrofits in E-series
eNBT Retrofit Adapters
NBT Navigation System Retrofit in E9x
Let us know if you have any questions!
