My new tint scratched, anyone else's too?
05-03-2014, 03:56 PM | #1 |
104
Rep 281
Just got my car tinted and upon lowering the windows for the first time, the tint scratched.
Now I cleaned the trim and windows before tinting and made sure no dirt was trapped by gaskets. Anyone else's got scratched as well? I have 2011 e90. I noticed there is a secondary gasket lower but it cannot be reached to clean. I guess I will have to pop door panel to clean it... Please share your experience. |
05-03-2014, 05:13 PM | #4 | |
43
Rep 120
Drives: 2006 325I ALPINE WHITE
05-03-2014, 05:50 PM | #5 | |
104
Rep 281
I'm thinking of removing the door panels and either cut or remove the secondary gasket that scratches the tint. I'm using llumar tint. |
05-03-2014, 06:13 PM | #6 |
35
Rep 1,652
Drives: '10 AW/CR e92 6mt 335i
Did you guys have moleskin installed with the tint?
05-03-2014, 11:13 PM | #7 |
26
Rep 276
It's the dirt thats trapped on the secondary gasket that is doing the scratches. I see it all the time on the BMW's. The solution is to get a moleskin which last a few years or do what my tint shop recommended and cut the secondary gasket.
2010 AW E90 335i M Sport
2012 GTR 2017 STi Limited 2018 LBB M2 DCT |
05-03-2014, 11:42 PM | #8 | |
Came to the N55 Darkside
1113
Rep 12,740
You simply cannot tint your E9x without it- it is critical. |
05-03-2014, 11:44 PM | #9 |
Rep 119
Drives: 2007 328xi e92 Blk on Blk
It's funny that you say that because I noticed scratches on my driver's side window after I got mine done a couple of weeks ago. It's Llumar too. Weird thing is it's now gone and I have no idea how. I could even run my finger over the scratches and feel that it was def scratched and not a streak of some sort. Maybe just give it a little bit and clean your window good and see if this "scratch" goes away.
"Workin' all day...now it's time to play...HEY! HEY! HEY!" - WIC
Current: 2007 328xi (e92) | 2012 Mazda 3 Hatchback Previous: 2006 Mercedes c350 4matic|2003 Nissan Maxima SE | 2001 BMW 323ci (e46) |
05-04-2014, 12:07 AM | #10 |
129
Rep 1,052
Yes. This.
It's well documented all over the place. Should definitely do research before installing anything on these cars even something as simple as tint. OP, Look up tint protector. Custom moleskin to protect. |
05-04-2014, 02:18 AM | #11 | ||
20
Rep 245
05-04-2014, 07:35 AM | #12 |
104
Rep 281
Thanks guys for your help. I ordered moleskin.
From the guides on moleskin installation, it looks like they install it on the first upper weather strip/grommet. I thought it was the lower one that scratched the tint? Also, some people don't take off the panel but rather pop the top portion. For those who installed moleskin, did you need to pop the whole door panel or just the top? Thanks for all your help. |
05-04-2014, 08:54 AM | #13 |
145
Rep 1,132
I recently removed my tint that was ruined by the secondly gasket, my tint looked as though I had my car full of stray cats clawing to get out! Before getting my new tint I pulled the top of my door panel open ( was very easy to do) pulled the window seal-gasket out and cut off the secondary seal with a razor blade. I'm sure bmw put it there for a reason but I have not noticed any extra road noise or other negative result from doing so.
05-05-2014, 11:06 AM | #15 |
I'll get back to you
7568
Rep 2,132
2018 Stinger GT
2009 E90 N51 /Active Autowerke Stage 2 tune/BMW Performance Exhaust/ Countermeasure enthusiast. |
05-05-2014, 11:58 AM | #16 | |
@orlandomma
Rep 88
05-05-2014, 12:34 PM | #17 |
818
Rep 2,869
everyone on this board with tinted windows most likely has the vertical scratches.
You need to wrap the window rails internally with some type of tint protector. Even if there is no "dirt" between the rail and window, even the slightest, smallest nick against the rail will scratch your tint... your car is probably not perfectly level or straight when you put your windows up/down.. so just that alone causes the window to hit the rail ever so slightly and leave scratches.
2019 X3 m40i:Carbon Black:Executive:Premium:Adaptive:Vernasca:699M:HK: Ambient:IND trim:M Mirrors:15mm spacers:Maxton lip:20% tint windows/pano:dsg paddles:TLG mudflaps
2008 328i E90 Jet Black:6MT:RWD:Premium:Sport:Xenon:MTEC V3 AEs:Front Splitters:CF spoiler:19" VMR FF v710 |
05-05-2014, 05:27 PM | #18 |
239
Rep 1,255
my passenger side window is scratched. I have no idea how it happened. At first I thought it was white shit stuck to the outside. I am going to have the window redone at some point.
05-05-2014, 08:58 PM | #21 |
10
Rep 300
My ceramic tint on my 2011 e90 scratched as well. Life goes on..
BMW Performance // Bilstein // Swift // ADVAN // COBB // Alpina // ER // AFE // Lux // P-Kics // Macht Schnell // Turner // Michelin // Wincos
05-05-2014, 09:17 PM | #22 |
533
Rep 2,872
I've had 20% on all my previous vehicles and throughout all of that time I received two tint tickets. One of which was because I had the original reason for being pulled over lowered to a tint ticket instead of a few over the speed limit. $54 including internet payment fee.
In NJ, depending on exact location, they really don't bother you much unless they're completely blacked out. OP, i've been kind of waiting on installing tint on this car since I've read alot about the tint being scratched by the felt/plastic strip. Moleskin should eliminate this issue, so make sure you install this before having the tint re-done! Moleskin DIY- http://www.e90post.com/forums/showthread.php?t=711764
BSM E90 6MT-JB4 G5 ISO-BMS DCI-Golf-Tee Mod-Hankook S1N2 Non-RFT-ER Chargepipe/TiAL BOV-E40 blend-VRSF V2's-M3 CDV-MHD/JB4 FLASH-VRSF 5" STEPPED FMIC
