Upgraded low pressure n upgraded high pressure fuel pumps
05-02-2014, 06:35 AM | #1 |
Rep 157
Hi seniors, just checking anyone has upgraded their low pressure and high pressure fuel pump yet ? Not going into methanol or e85 yet but likely to upgrade turbo in near future ...
Read about walbro 255 but could anyone guide me on the part number ? Any links or good recommendation of the high pressure fuel pumps ? If e85 pumps is not ready in a certain country, how do you resolve this issue ? Pls guide a newbie ... I have Cobb ap v3 and full bolt ons but need more poisons... |
05-02-2014, 08:33 AM | #4 | |
Rep 157
Pls elaborate |
05-02-2014, 10:06 AM | #5 |
Came to the N55 Darkside
1113
Rep 12,740
I guess I don't quite understand what you're trying to do- are you trying to replace your fuel pump with a different non-OEM high-pressure one? Or...
05-02-2014, 10:14 AM | #6 |
101
Rep 1,597
Why do you want to upgrade them?
Get a bigger turbo first and THEN you can think about a fuel pump! No need to change it now because the small turbo is your biggest problem at this point!
BEFORE: 130i N52 (2006-2011)
NOW: 335xi N55 (2011- ) |
05-02-2014, 12:32 PM | #7 |
Rep 175
Drives: 2011 335i 6MT
First of all the walbro pump is just to replace or help the stock LPFP, I don't know of any upgraded HPFP out there.
Second, unless you are upgrading the turbo AND going E85 you do not need the upgraded LPFP. If you really want to add a fuel pump then its probably easiest to do an inline pump to help out the stock one. |
05-02-2014, 12:42 PM | #8 |
456
Rep 6,478
How do the 55s do in terms of fueling? I can’t say I’ve spent much time looking into that motor when you start to push it.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
05-02-2014, 01:12 PM | #9 |
Rep 157
I just did protuned and at 652 max torque I suspect my fuel pump is not sufficient. Ie. to say at certain rpm ie 2-3.5 k it is like choking. If lucky I get away with it. If not it knocks n give me a half engine check line with numerous trembles.
That's y I like guidance if to upgrade the low fuel pump at this stage? Or senior feel it is sufficient ? Which means I have to down tune |
05-02-2014, 02:14 PM | #10 | |
Rep 157
05-02-2014, 02:27 PM | #11 | |
245
Rep 1,595
Drives: 2011 335i xDrive Msport
05-02-2014, 02:29 PM | #12 | ||
Rep 157
Guess I will not require low or fuel pump upgrades at this stage. So it must be the tuner which must have did something wrong then. |
05-02-2014, 02:31 PM | #13 |
456
Rep 6,478
Depends, the hit on spool is pretty gnarly (at least on the 54). I’ve seen the high pressure side drop below 1K PSI on spool. Not that it gets better up top, but IMO its’ on spool where you really need to watch it.
05-02-2014, 04:06 PM | #15 |
245
Rep 1,595
That has more to do with how fast it can react to demand instead of ultimate flow rating. You flow the most fuel at higher RPM normally (unless you run leaner or artificially cut boost at higher RPM).
05-05-2014, 10:12 AM | #16 |
Rep 175
N55 has better fueling than N54 but if you really want to upgrade the lpfp here is a link. It is for N54 but is still applicable.
http://www.n54tech.com/forums/showthread.php?t=17458 |
05-05-2014, 09:23 PM | #17 | |
650
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
There are some logs here. I am getting the vargas turbo and a walbro 465 lpfp installed right now and will see how I go tuning with more e85. |
05-06-2014, 02:42 PM | #18 | |
26
Rep 195
Wagner EVO II C | Akarpovic SS Evolution Exhaust | Cp-e DPs | Koni | CV5F Forgestar et 32/38 on 255/35/19 & 275/35/19 | DW400 | Swift spec R | N20 sensor | PB Valve Cover | GCL | M3 control arms | JE forged piston kit | Carillo forged rods | Ported Head | F80 DMFW |
05-06-2014, 07:46 PM | #19 |
38
Rep 634
05-06-2014, 08:19 PM | #20 | |
650
Rep 2,601
Might dyno with normal fuel depending how much time and patience I have with tuning. Priority will be the ethanol tune though. |
07-20-2021, 05:55 AM | #21 | |
Rep 6
Do you know of any Stage 1 upgrades available (E90, 320d) |
07-20-2021, 07:30 AM | #22 |
164
Rep 411
