04-30-2014, 04:19 PM | #1 |
95
Rep 809
Drives: 2014 228i Msport
USB ports
I know there's one in the center console but wasn't there also supposed to be one in the glovebox ?
A peasant and proud of it
Save The Manuals!!! |
04-30-2014, 07:29 PM | #3 |
4972
Rep 10,200
Drives: 2024 Golf R / 2022 718 Spyder
I don't remember seeing anything about the glove box.
However, BMW does sell an adapter that goes into one of the 12v slots that has 2 USB slots - you can find it on here, I just can't remember which thread it was in.
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
04-30-2014, 07:36 PM | #5 |
European Editor
10528
Rep 22,992
IF you have Nav (w/hard drive) then you will also have a 2nd USB slot in the glove box.
04-30-2014, 08:06 PM | #6 |
4972
Rep 10,200
Right on - good point.
05-01-2014, 04:43 AM | #7 | |
1773
Rep 4,510
F2X series cars fitted NBT Pro nav do not appear to have the 2nd USB port in glove box. My Q4 '13 build M135i with pro nav NBT doesn't have it.
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
05-01-2014, 09:32 AM | #8 |
Rep 56
05-01-2014, 04:59 PM | #10 | |
European Editor
10528
Rep 22,992
@bungee91
@b_ack51 Quote:
Humm... well, maybe they don't then. My car doesn't have Navi, but on other e82's ('10's and up)that do have it I have seen an extra USB slot in the glove box. Maybe ask your dealer or BMW NA >?
05-16-2014, 09:08 AM | #11 |
14
Rep 131
Should I not be leaving a thumb drive in the center console USB port when the car is parked (overnight, or for many hours at a time)? Does it draw power constantly and potentially drain the battery?
05-16-2014, 09:22 AM | #12 |
204
Rep 757
It is completely safe to leave the usb stick plugged it. It will not draw power when the car is turned off.
05-16-2014, 10:01 AM | #13 |
8
Rep 79
page 139/140 of the owners manual says WITHOUT professional navigation/TV the USB is in the glove box. Vehicle WITH prefessional navigation/tv the USB is in the center arm rest. it's one or the other, the car only has one usb port.
05-16-2014, 11:23 AM | #14 |
14
Rep 131
Ok, that's good. The main reason I asked is because when I get into the car and before I turn it on, if I plug in the stick, there's a little LED on it that lights up. Maybe that's because the key is in range so the car is in some sort of "pre-start" mode where some components become active? But if the key is out of range, no power would go to the stick?
05-17-2014, 05:43 AM | #16 | |
95
Rep 809
05-25-2014, 11:33 AM | #17 |
Rep 1
I have a UK RHD version with Business Navigation and it has two USB ports. One in the glove box and one in the arm rest.
However the only thing I seem able to do with the glovebox port is save/load user profiles to a USB. My understanding is that with the professional navigation you are able to use the glove box port to save media to the internal hard drive. |
