04-29-2014, 08:04 AM | #1 |
953
Rep 1,456
Proper engine warmup?
Can anyone tell me if you need to warm the turbo engine up before taking off like you should do in an N/A engine when it is cold outside say 50 degrees or less. All of my previous engines were N/A and I would wait til RPM's dropped down before taking off. Thanks, I have no experience with turbos.
04-29-2014, 08:24 AM | #2 |
1270
Rep 4,703
same thing applies to the turbo
the ecu also monitors the oil temp and won't create max boost until the temp hits the target value (not sure what that is) |
04-29-2014, 08:30 AM | #3 |
Rep 103
In fact, warming up a turbo engine is even more important, as it is that very oil which lubricates the turbos (unless the turbos have a closed loop oiling system), and cold oil doesn't lubricate very well.
However, most modern turbo engines do have some sort of control via the ECU that will not allow full boost until the engine is warm, as 2kaccordcoupe alluded to. Even with that, though, you really want to go easy until the temp gauge starts to move. |
04-29-2014, 10:47 AM | #5 | |
10
Rep 235
But as the other members already stated, don't do kickdowns or full throttle until the engine is warm. |
04-29-2014, 11:02 AM | #6 | |
230
Rep 3,899
It is also important with turbo engines after a hard drive to drive the last few miles moderately to allow the turbos and other components to cool.
2014 AW F80 M3 DCT
2011 AW E90 M3 DCT - Sold 2010 JZB E90 M3 DCT - Sold 2009 6MT E90 LCI 335i M -Sport - Sold |
04-29-2014, 11:21 AM | #7 | ||
M3AT LOVER
322
Rep 1,853
2015 F80 M3 | SSII ext SO int | M-DCT | 19" Black Wheels
Keeshdotcom7.50 |
04-29-2014, 11:35 AM | #9 |
Rep 103
Yep. Very important to do so, to prevent coking the oil onto the turbos. Especially after tracking the car, you want to do a cool down lap, and let the car idle a bit before shutting it off completely.
04-29-2014, 01:04 PM | #10 |
434
Rep 1,732
If you let the motor idle when cold does it damage the engine? Where I live it get really cold in winters and to just jump in an drive that just seems mad. The temps could get down to -40 C (colder with the wind).
04-29-2014, 01:18 PM | #11 |
230
Rep 3,899
It takes a lot longer for the oil to circulate and protect your engine when just idling. Follow what BMW recommend - get in and drive moderately until engine is at operating temp!!
2014 AW F80 M3 DCT
04-30-2014, 12:08 AM | #12 | ||
47
Rep 164
I remember in the 80's that all the turbo cars needed cooling down, a hot aftermarket item was a turbo timer to help with the process.. I would always do a cool down lap at the track regardless of the type of engine, but how long should I let the car idle after spirited driving? |
04-30-2014, 04:22 AM | #13 | |
230
Rep 3,899
2014 AW F80 M3 DCT
04-30-2014, 10:20 AM | #14 | |
M3AT LOVER
322
Rep 1,853
04-30-2014, 11:14 AM | #15 |
230
Rep 3,899
As long as youre not thrashing the car it should be fine. My journey to work is about the same and barely warms the car up. I save my spirited drives for after work and weekends
2014 AW F80 M3 DCT
04-30-2014, 11:57 AM | #16 |
M3AT LOVER
322
Rep 1,853
Hehe, the only "spirited" driving I do when driving to work is waving my fist at my fellow drivers.
04-30-2014, 02:43 PM | #17 |
2936
Rep 3,286
Drives: 2002 M5;2007 M Coupe;2020 M2C
All my M cars' oil temp gauges have two dots on either side of center which illustrate the proper temp range for spirited driving. I've had a lot of seat time in the 1 M as well, and it has the dots also (and takes forever to get past the first dot compared my my naturally aspirated Ms...). The AW/SO car in the delivery thread doesn't seem to have the dots. Does the owner's manual specify the correct oil temp range? Maybe BMW doesn't care any more, as teh M235i doesn't even have a oil temp gauge!
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel 2007 E86 Z4M Coupe Silver Gray/Black 2021 Kia Telluride (hauler) |
05-06-2014, 01:00 PM | #18 | |
846
Rep 3,249
^This is perfect. I would only add that it also prevents coking in the lines as well. /end thread. |
06-25-2014, 03:52 PM | #20 |
Boost Patrol
30
Rep 79
Like any engine (turbo or NA), it is important to let the coolant and oil temps warm up before you mash it. Especially though with a turbo engine you want to make sure that oil running to the bearings,etc is up to operating temp before you go into high boost.
My rule of thumb is drive around before WOT and less than 4k rpm for 10 minutes when starting cold. And also avoid that too in the 5 minutes leading up to turning the engine off. |
06-25-2014, 04:08 PM | #21 | |
BMW Fan Boy
446
Rep 1,385
Just stay out of boost until the oil temp needle starts moving. I really would not worry too much about driving easy before turning the engine off, unless you are coming off of a track or something. I believe the F80 will continue to circulate oil to the turbo's after shutting off the engine, when the oil temp is really hot, to avoid coking the oil. |
06-25-2014, 04:41 PM | #22 | |
2095
Rep 43,350
