can I change the eccentric shaft sensor gasket without removing the valve cover?
04-29-2014, 07:11 AM | #1 |
95
Rep 338
its seeping oil but the sensor seems ok, so I just want to replace the gasket. thx in advance
04-29-2014, 03:10 PM | #3 |
95
Rep 338
I just want to change the gasket, not the sensor. The DIY on changing the sensor calls for installing the new gasket after the valve cover is bolted in place, so why cant I just pull out the old gasket and press in the new one? I am sure I can handle removing the valve cover if needed but seems to be a PITA so would like to avoid that if possible. Thanks
04-29-2014, 07:44 PM | #4 |
47
Rep 1,160
I remember watching this video when i was having my eccentric sensor problem, looks like if you're just changing the seal you can just unplug it and replace. But if your seals bad most likely your sensor is too.
Monaco Blue 330xi - Terra Interior/6-MT/Sport/Premium/Cold/CSL's/M3 Spoiler Lip/Black Kidney's
StradaRedlands4940.50 |
08-12-2019, 12:13 PM | #8 |
Rep 66
Don't mean to bring this from the deal. Tackling this myself. Any suggestions and recommendations not to break the seal and having to do a VCG job? Thanks
04-11-2023, 12:00 AM | #10 |
Rep 7
