Problem removing waterpump+thermostat
04-20-2014, 10:48 PM | #1 |
Slow driver
24
Rep 186
Drives: 2008 E90 335i
I am trying to change my water pump and thermostat but I am currently stuck in the step where I pull out the pipe that connects to the thermostat. If you go to the video I linked below and skip to 11:00, you will know which pipe I am talking about. I have spent hours prying it out but it has not moved 1 bit. I also removed the clamp already. Do you guys have any suggestion on how it can be taken out? Additionally, the thermostat on the car right now is made by plastic, not like the one in video.
Million thanks! Last edited by FrankyTheCyborg; 04-21-2014 at 12:40 AM.. |
04-21-2014, 06:23 AM | #2 |
58
Rep 665
By "clamp" I'm assuming you mean the retaining clip, and yes, it's best to remove it completely while you fight with the quick-connect. Unfortunately, there's no real trick to removing it. Some are easy to remove and others can be a real bitch. You need to pry at different locations while wiggling and twisting the connector. Keep at it -- it will give eventually.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
2016 Jaguar F-Type S AWD - Polar White/Cirrus |
04-21-2014, 06:35 AM | #3 | |
106
Rep 483
04-21-2014, 12:49 PM | #4 |
Slow driver
24
Rep 186
Thanks for the reply. Gonna try it again in these few days. It is so frustrating
04-21-2014, 01:27 PM | #5 |
13
Rep 162
Wiggle the thing up and down while pulling straight out. Do not twist as they only fit one way (small plastic tab).
It'll take some fighting to remove. If you have a heat gun, blast it here and there to help loosen it a little too. |
04-22-2014, 09:44 AM | #6 |
421
Rep 1,643
Ah, yes the old "quick connect". Or, "slow disconnect" as it should be.
I had the same problem with these. Called a tech buddy of mine and here's what he recommended I it won't come off: 1. Remove clip completely 2.spray wd40, and wiggle it 3. If it doesn't come out, try #2 again a few more times. Spray it allover and inside where the clip was to remove as much grime as you can and try pulling/wiggling 4. If it still won't come out, take a flat head screw driver and ever so gently try prying along part of te edge - just a gentle twist of the flathead here and there over and over. Eventually, combined with the lube, it will start to give. Warning - if you pry too hard you'll break the connector an then your screwed bc no one carries these in stock.
2007 E92 335i MT
