2010 2011 BMW 5 Series Forum F10 Code party in Atlanta or nearby? |
04-18-2014, 05:21 PM | #1 |
33
Rep 286
Are there any coding geniuses in the Atlanta area? I know that I will want to have some stuff moved around modified or whatever when my car gets back.
Anyone near the southeast that can make this happen? How hard is it to do and what kind of equipment do you need? Is it basically just the same stuff that the dealer has or is it more simple than that? Thanks! |
04-18-2014, 05:26 PM | #2 | |
73
Rep 363
05-19-2014, 02:31 PM | #4 |
Rep 24
Drives: 2013 535i xDrive
Me too, I have just moved to Atlanta from Denver, and I have the cable as well, but I could use some help on doing it the first time.
07-09-2014, 09:40 PM | #5 |
55
Rep 670
not from the area ... but if you want me to code it remotely I can do it for you at no charge
07-11-2014, 11:55 AM | #6 |
33
Rep 286
Cool thanks! What coding can be done to the car that you know of? I just went ahead and added the Extra Bluetooth to my build, and I now found that this is a codeable feature. But what else?
07-11-2014, 12:09 PM | #7 | |
55
Rep 670
• Enable (Sport Displays) Torque & Power Meters In iDrive • Start Car Without Braking/Clutching (just push the power button) • Disable DRL’s • Disable Amber Side-Marker Running-Lights (Still Work As Turn Signals) • Disable Headlight Washers • Change Amount Of Sprays For Headlights Washers From 2-3 or any # • Enable the display from Rear & Side-View Cameras at all speeds • Angel Eye Brightness 100% during DRL and Headlights • Enable Full-LED Headlights (Dazzle) (Remove De-Coding for US LED Headlights) • Enable Siri Voice Control from Steering Wheel • Increase the brightness of ambiance lighting • Initial 3 Gongs/Sound @ Start-Up OFF • SeatBelt Reminders/Sound OFF • Auto Start/Stop OFF by default • Auto Start/Stop – Remember LAST Setting • Unlock all doors with engine off (Single-Pull Handles) • Electronics off when driver’s door opened (Press Power Button 1x and exit car) • Close Mirrors/Windows/SunRoof from Key Fob or Comfort Access • Set Mirror Fold Delay Time for Key Fob or Comfort Access • Tilt Passenger Mirror farther down when in reverse • Opening FRONT doors won’t interrupt windows Auto-UP feature • Rear Tails & Angel Eyes on as DRL • Fog Lights stay on w/ High Beams • Brake-Force Flashing on Hard Braking(Blinking Brake Lights on Hard Stop) • High-Beam Assistant – Auto-On • Welcome Lights o Add Fogs to Welcome Lights • Close/Open Trunk from Fob & Kick Panel Button • Set cell phone ringer as primary tone in the car for incoming calls • DVD In-Motion (Watch DVD on iDrive screen while driving) • Navi Trip-Import from USB • Enable Playing Video Files from USB (XVID, XVCD, OGG, MPG, AVI, MKV, DIVX) • Add GPS Current Location to Navi Menu Items • Add Turn-Signals to HUD • Add Temperature & PSI to tire monitor screen in iDrive • Disable Legal Disclaimers (Initial Welcome & Cameras) • Change i-Drive Animation to ///M Logo • Enable IPCE Web Server @ 172.16.222.1 • Enable WiFi Hot-Spot • HVAC System Remembers Last Setting • Opening REAR doors won’t interrupt windows Auto-Up feature • Auto Wiper Sensitivity Increase • Show Digital Speed in MPH in Cluster • Show Turn Signals in HUD • Enable GPS-Sync for Clock (HU_CIC Only – Prior to 2012) • Enable HUD for Entertainment & Phone List via Steering Wheel Scroll-Wheel (HU_NBT Only – Prior to 2014 when it was default on) • Change Temperature Settings for Seat Heating Presets • Change Temperature Settings for Seat Cooling Presets • Decrease Delay for Open/Close Trunk via Comfort Access Hand Free Last edited by pillpusher84; 07-11-2014 at 10:51 PM.. |
07-11-2014, 04:46 PM | #9 |
55
Rep 670
send me an e-mail (my PM is turned off on the forum) @ *************************
I will send you the software, cheat sheet for F10 and everything you need to get going |
11-01-2015, 11:44 AM | #11 |
Rep 4
Anyone that can help in installation and coding? I bought a digital instrumental cluster, auto dimming mirrors, steering wheel and a automatic shifter. Please let me know if you have experience or know someone/ shop that could do these jobs. Thank you!
