2010 2011 BMW 5 Series Forum F10 Carrozzeria - BMW F1X 528i 535i 550i M5 Vent Integrated Digital Interface |
04-17-2014, 04:29 PM | #1 |
61
Rep 509
Carrozzeria is now a proud supplier for P3Cars Digital Interface Gauges! These gauges are a beautiful addition to your existing 5 series! With the option to buy without a Pre-Installed OEM Vent if you want to give it a try yourself with your own gauge, or the option to get Black Slats or Steel Slats vent with the digital interface Pre-Installed we have you covered! "Connect with your car in an entirely new way. Why settle for just a boost gauge? Sporting features available in products 3x the price, this is a swiss army knife of performance data, with design and integration that won't spoil the clean lines of your interior. Specifically designed to support the 2011+ F10 BMW 5 Series platforms including the 528i, 535i, 550i, and M5. Plug and Play install Quick plug and play install with zero cutting required. All power and ground connections come directly from the low profile concealed diagnostics port connector. Boost/Vacuum Display High resolution boost/vacuum display showing actual manifold boost, Read Boost/Vaccum via diag port directly, no tap required. Multiple Gauge Displays Boost/Vac, Coolant Temp, Intake Air Temp, Exhaust Gas Temp, Throttle Plate, Speed, RPM with Shift-light, Battery voltage and more! Peak Recall & Run Record Recall the peak value from any mode, or record and playback 15 seconds of data from the current mode. Temperature peaks recorded in the background. Universal Aux Inputs Includes additional inputs to optionally connect any 0-5v sensor with universal settings for display ranges and bargraph displays from -999 and 9999 max values. On the Fly Configuration Menu Lockout/Display off mode, English(PSI, F, MPH) or Metric(BAR, C, KPH) selection, Adjustable boost display resolution, Ambient Calibration for boost sensor and more!" These start as low as $389 and are available for RHD and LHD! Contact us for shipping and details on pricing with vents included! http://www.youtube.com/watch?feature...&v=POF_ySw5_wk Please feel free to PM us here or email directly Jesse@CRZMotorsport.com Thank you! - Jesse Ian Last edited by Carrozzeria; 04-18-2014 at 12:15 PM.. |
04-23-2014, 01:49 PM | #5 |
61
Rep 509
2 units sold in a day! Make sure to let us know which model you have and if you're looking for the gauge alone or with a vent and which color vent if so
05-01-2014, 09:59 PM | #12 |
Slowbmr
7
Rep 18
Drives: 2018 Bmw M4 Comp Purple Silk
Got my order today and didn't take me long to install!! The only thing I can say is the two little bolts holding in the vent were a b*tch to get out!! I broke one, but don't care LOL Took me about 30 minutes total and I love the gauge! Would highly recommend.
Here are some photos from my 2013 528ix
Slowbmr - R61 Purple Silk F82 w/Ultimate & Competition Package featuring Opal Merino Extended White Interior
05-02-2014, 01:39 PM | #13 | |
61
Rep 509
I'll have to get a DIY going for these to send with them |
Tags |
carrozzeria, p3gauges |
