04-17-2014, 03:13 PM | #2 |
10583
Rep 6,920
Drives: 2018 M2 AW DCT
I never use one.
04-17-2014, 05:43 PM | #4 |
47
Rep 287
Drives: '15 GT-R, '02 996TT
I run the Escort 9500. Its a bit old, but it does the job.
I don't typically speed, but I've gotten tickets before doing 75 on the highway so it helps lol. |
04-17-2014, 09:00 PM | #5 |
Rep 56
I setup an Escort Passport Max mounted just lest of the iDrive screen right above the dash.
Running the wire to the dash was easy enough, and there is enough gap between the dash and the A-pillar cover to sneak the wire in and be completely hidden. I know many like to mount it high, I prefer mine low and is what is advised for laser detection (even though that is kind of BS, but whatever). I used the smart cord installation and mounted the smart box on the right of the steering column, and removed the paneling under the drivers side and tapped the switched 12v+ of my reverse camera module (or that's what it seemed to indicate). It works very well, I will attach some pictures if they may be of help. |
04-17-2014, 09:03 PM | #6 |
4516
Rep 8,942
You can also tap the mirror for power it's a 5 min install. PM me for link to good write-up if you're interested I saved the link on my PC.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
