Do I need to reset ECU after spark plug change?
04-16-2014, 03:13 PM | #1 |
54
Rep 504
Hey,
I recently got a check engine sign which was due to misfire. I changed all my spark plugs with the Bosch ones and one bad coil. Car is smooth and does not give any more symptoms of a misfire. But only while idling in park, i feel a slight hiccup once in a while. I was reading around that you need a BT tool to reset the misfire code (no check engine sign), or I can unplug my battery for an hour or so to reset the ecu to get use to the new sparks. Or will the ecu adapt by itself ? Thank you, Teddy |
04-16-2014, 04:26 PM | #2 |
30
Rep 644
No reset. You can reset adaptions but that isn't necessary. It will adapt on its own. The slightly rough idle can be carboned up intake ports if you have more than 80k KM and haven't had the walnut blast done.
04-16-2014, 04:27 PM | #3 |
54
Rep 504
04-16-2014, 04:31 PM | #4 |
35
Rep 1,652
Drives: '10 AW/CR e92 6mt 335i
Can you explain the "hiccup"? What are the symptoms? Like the revs go up and down on it's own in idle? Might not be that serious. Worst case, its carbon.
COBB AP Stg 2+ FMIC Aggressive | VRSF 3" Catless DP | COBB FMIC | BMS DCI | CP-e Metal Charge Pipe | 370+ whp/435+ lb.ft torque
04-16-2014, 04:35 PM | #5 |
54
Rep 504
04-16-2014, 06:59 PM | #7 |
54
Rep 504
04-16-2014, 07:06 PM | #9 |
54
Rep 504
04-16-2014, 07:09 PM | #10 |
70
Rep 628
Its a possibility, Osirisman is right, shouldn't have rough idling or hiccups at such low mileage due to carbon. I remember I had slight hiccups when wot (wide open throttle) turned out to be a loose injectors.
04-16-2014, 07:11 PM | #11 |
54
Rep 504
Its not rough idle, it settle bellow 600 rpm and does not move. I just feel a slight hiccup like every 5-6 mins in idle only when in park, not drive.
04-16-2014, 07:15 PM | #12 |
70
Rep 628
Rough idle doesn't necessarily mean the idles bounce around, but you feel the rough shaking or as you describe hiccups, and can't really say what it is but that sounds carbon related, hope you figure out soon, check the plugs as well if you want too.
04-16-2014, 07:17 PM | #13 |
54
Rep 504
Its not rough shaking, its like a hiccup.. Its there for 1-2 seconds max and disappears.. Can this be because my car is getting used to the new sparks and the new coil?
04-16-2014, 08:26 PM | #14 | |
Rep 74
E90 328I 6MT black on black- wifey's DD
Tinted Windows|Sport Springs|Koni Yellows|OEM ZCP Wheels| E46 M3 Garage Queen- Adrenaline Machine Competition Model, with a nice mod list. |
04-16-2014, 09:07 PM | #15 |
54
Rep 504
04-16-2014, 09:29 PM | #16 |
Rep 74
Vendor doesn't matter just MFG. Im not familiar with the N54 so hopefully someone else has a good idea.
