Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Oil cap sucking air
      04-15-2014, 10:12 PM   #1
Shindog32
Shindog32
Drives: 325i
Oil cap sucking air
I recently had an overheating problem and Im in the process of replacing my EWP and TS. While i was checking under the hood for signs of overheating damage I removed the oil cap to check for water in the oil and noticed that after I put the cap back on ther was a hissing sound while the engine was running? Removing the cap while the engine was running caused the check engine light to come on and I cant get the hissing noise (vacume leek) to go away. This may sound like a stupid question but did I remove it incorrectly or is it normal to vent a little? The gasket looks fine BTW.
      04-16-2014, 11:56 AM   #2
Shindog32
Shindog32
Drives: 325i
Anyone have any thoughts on this?
      04-16-2014, 12:24 PM   #3
jwzimm
jwzimm's Avatar
Drives: '16 M3
Well we have PCV (Positive Crankcase Ventilation) which uses intake vacuum to draw air out of the crankcase and through the motor. Opening the oil cap while running will spoil the seal in the crankcase and I wouldn't be surprised that the CEL came on from that. As for why the cap won't seal again, not sure. It could be that it is designed to vent a little (to provide flow into the crankcase for the system to work) but I don't know that. Maybe just need a new 710 cap (oil cap).
2008 Honda S2000 - Current
2016 F80 M3 - SOLD!!
2011 e92 X-Drive Coupe - SOLD!!
      04-17-2014, 09:09 PM   #4
GMWNashville
Drives: 19 G05, 16 F80, 10 E70x5D
This engine uses very very little engine vacuum (hence the need for a vacuum pump) you possibly have a bad valve cover which has the pcv system integrated in
      04-18-2014, 09:09 AM   #5
Shindog32
Shindog32
Drives: 325i
Problem solved! I have 71000 on this car and have never changed the oil myself. Come to find out the retainer ring is not supposed to come off with the cap! It did and when I put the cap back on I did not "snap" the ring on first. Once i did this right no more vacume leak. Feel free to insert rookie remarks and dumb a%# replies at will.
