04-13-2014, 04:03 PM | #1 |
124
Rep 704
Drives: 2014 328d
What do you know about turbo timers?
Someone brought this up in a thread the other day and I had never heard of them. I know what they do, but how complicated is it to set one up? How expensive? Are certain manufacturers preferred over others? Is the turbo timer needed for average rpm runs or just when you've run the car at high rpm for a while? I'm the kind of guy who will either just be too impatient to let the engine cool down, or will just forget. I'm particularly interested in their usage with diesel engines since I have a 328d.
2014 328d SportLine
04-13-2014, 04:41 PM | #2 |
13
Rep 129
I know they're utterly useless...
Just idle it yourself for one minute OR drive calmly before you stop. Don't go full retard and install one just because you're a bit lazy and don't want to sit and wait |
04-13-2014, 04:59 PM | #3 |
124
Rep 704
Drives: 2014 328d
OK, I like it!--especially the "full retard" part.
2014 328d SportLine
04-13-2014, 07:23 PM | #6 | |
890
Rep 7,047
Systems are in place to make sure your hot turbo doesn't continue to cook once you shut the engine off. |
04-13-2014, 07:53 PM | #7 |
1432
Rep 4,723
^ yes. The water pump will run and cool the turbo(s) after you park.
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
04-14-2014, 06:18 PM | #8 | |
Curmudgeon and Pedant
690
Rep 3,489
04-24-2014, 07:30 PM | #9 | |
124
Rep 704
Drives: 2014 328d
Now let me ask you (& others): How hard would you have to run the engine in order to risk some damage without appropriate cool down? This is a ballpark estimate of course.
2014 328d SportLine
04-25-2014, 12:35 AM | #10 |
690
Rep 3,489
I've never really worried about it; but then I have a 2 mile 30 mph drive to get to my house. I'd say a couple minutes should be sufficient to circulate enough oil and water to get them cooled down?
04-25-2014, 08:52 PM | #11 |
124
Rep 704
Drives: 2014 328d
I'm not sure you understood my question. I was asking about how hard & long would you have to run the engine so as to risk some damage WITHOUT a cool down period when stopped?
2014 328d SportLine
04-26-2014, 09:41 AM | #12 | |
690
Rep 3,489
These engines are overkill and don't even warm up all the way unless you're climbing a hill. Search around for TDIwyse's thread where he was talking about cold-weather warmups and posted a coolant temperature graph for his commute - a couple years ago now. He's also posted a recent graph of exhaust temps that show rises when he's doing ET kinds of things, and mentions not seeing them rise otherwise. |
04-26-2014, 11:24 AM | #13 | |
3487
Rep 9,709
Almost all modern turbo's have a water jacket to cool them. It isn't when they are running that it is critical, more an issue with the turbine side potentially being at around 2000DegF when stopped, causing oil to coke on the turbine shaft, due to it heating up under heat soak. This coking then eats into the (old style, many now have ball bearings) journal bearings, causing premature wear. In your case, the problem is far less of an issue in the case of a diesel. Diesel EGT is significantly cooler than petrol, typically around 1400F instead of 2000F. Also, when idling a Diesel EGT is lower too, adding to the cooling effect. Google images of a petrol turbo system glowing red hot, this can happen on even stock street cars. It is not likely to happen on anything other than highly tuned diesel engines. This plus the water jacket which adds mass to dissipate the heat in the turbine, plus fully synthetic oils, plus better bearings, all lead to much more 'tolerant' turbo system. As long as you run the engine off boost for say 20-30 seconds (parking up), the turbo will have cooled to well below the threshold that causes the oil coking issue. This is what a Petrol engine has to put up with, and the reason why a TT is a good idea, if you drive it hard without cooling. |
04-26-2014, 03:38 PM | #14 | |
124
Rep 704
Drives: 2014 328d
2014 328d SportLine
