04-10-2014, 09:59 AM | #1 |
22
Rep 149
Wheel Size
Does anyone already have an idea on which size of wheel is going to fit on the M4 without rubbing. I'm a bit curious because I found out that the Performance wheels are only 8" and 8.5" or so.
My car is supposed to be delivered by end of June and I would like to order a KW Clubsport and some 20" wheels so my dealer can mount everything straight away for delivery. But - right now I have 10inch wide wheels on my M3 E92 and I wonder if 10.5 will fit on the M4 without any bodywork needed - if yes which ET? |
04-14-2014, 06:51 PM | #3 |
704
Rep 886
You will have at least a half inch on the inside and outside of the wheel...in terms of wiggle room. That being said, a 19x10 up front and a 19x11 in the rear will definitely work.
As for offsets, the front is +29 and the rear is +40, so anything around that (or a little lower) will work and not give you much of a problem. If you want to get more aggressive with fitment and need camber, you'll have to wait until camber plates come out. Hope that helps!
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs |
04-15-2014, 07:50 AM | #4 | |
22
Rep 149
05-28-2014, 01:01 AM | #5 |
M4 Redliner
Rep 98
I tried ordering some vorsteiner wheels for mine and they're saying the same. No exact measurements yet. They did say 20s will fit but only with 25 profile rubber.
06-02-2014, 03:00 AM | #6 |
22
Rep 149
