Installed Black M Performance Grills Tonight on my MW M235i |
04-09-2014, 09:03 PM | #1 |
56
Rep 84
So I installed the M Performance grills tonight. I took the easy way out by cutting one of the slats of the OEM grill. If you do this right, this is a 10 minute install and you preserve the OEM grill (although one slat has a non-noticeable cut in it).
All you need for this install is something capable of cutting through the lower border of one of the grill slats. No bumper removal necessary, and you don't even need to unbolt the bumper. Before shots: I made a cut here: I then reached my hand through the hole as I bend the slat out of the way, release the 7 brackets, and the kidney pops right out: Black pops in: Same on the opposite side: Completed project: |
04-09-2014, 09:27 PM | #3 |
4515
Rep 8,942
Looks great huge improvement. Since you went through the grille, do you think it would be possible to skip the cut and undo the clips with one of these tools? Otherwise could you easily fit your hand in there? Seems pretty tight.
http://www.amazon.com/gp/aw/d/B000FB...=ATVPDKIKX0DER
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
04-09-2014, 09:45 PM | #4 | |
54
Rep 140
04-09-2014, 10:15 PM | #5 | |
4515
Rep 8,942
Was getting the bumper back / aligned properly an issue? Any play in the screws? |
04-09-2014, 10:32 PM | #6 |
59
Rep 595
Drives: 2014 BMW M235i
Once you get one of the grills out resist the urge to pop in the new one and use the opening you made on one side to remove the other grill on the other
2014 M235i | Manual | Estoril Blue / Terra | Tech, Premium, HK Audio, & Driver Assist | M Performance Exhaust, Stainless Steel Pedals, Black Kidney Grilles
Euro Delivery Trip Report |
Miata1385.50 Bluesmobile34.50 |
04-10-2014, 04:16 AM | #8 |
255
Rep 1,040
After looking and reading more about the procedure letting one of the OEM grills to be sacrificed for the cause is the easiest way to go here. Guess we can put the good one left after change up in the classified area for those who will need to return back to stock.
04-10-2014, 07:05 AM | #9 | |
77
Rep 408
'14 M235i(current)ED
'11 E93 M3(past)ED '08 E90 328i(past)Local |
04-10-2014, 07:13 AM | #10 | ||
54
Rep 140
Honestly, it's worth a shot. The bumper can be pulled out a lot more than you initially think. I'm used to having to remove the entire bumper to swap the grills on my old car, a Volvo C30. THAT was a pain. |
04-10-2014, 07:23 AM | #11 |
1867
Rep 13,043
Drives: BMW M340I G20
There was barley a 2" gap when I undid mine. No chance of getting my arm in.
Current car.M240i. Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci. |
04-10-2014, 07:42 AM | #12 |
103
Rep 1,254
I can't imagine this is much different then the 135i. The slots when the grill is out look exactly the same.
DIY's for grill replacement http://www.1addicts.com/forums/showthread.php?t=210582
04-10-2014, 07:46 AM | #13 | |
54
Rep 140
04-10-2014, 08:06 AM | #14 | |
56
Rep 84
I'll also add, the picture I included of where I made the cut is after the slat has been cut. If you simply cut the bottom portion and bend the slat out of the way, you can leave the top attachment in tact. If I needed to go OEM for any reason, I could pop the chrome ones back in and nobody would be able to tell they were even cut (of course, I would know). Make a nice clean cut at the bottom only and you should be good. |
04-10-2014, 08:07 AM | #15 |
56
Rep 84
I tried this method on my F30, but I ended up with two broken brackets in the bumper cover. I wanted to absolutely ensure preservation of the bumper cover brackets this time, even at the expense of a cut in the OEM grill.
04-10-2014, 08:52 AM | #16 |
1867
Rep 13,043
Same here I wasn't going to risk a new bumper for the sake of a grill I was never going to use again.
04-10-2014, 10:50 AM | #17 |
255
Rep 1,040
Agree. If you have no need to keep the original grills cut them out. For us leasee people it would be nice to have a working procedure to recover the grills in order sell the black ones later.
04-10-2014, 12:29 PM | #18 | |
4515
Rep 8,942
2022 Macan S
04-10-2014, 01:49 PM | #22 | |
4515
Rep 8,942
2022 Macan S
