Information Memory Error Codes
04-09-2014, 07:24 AM | #1 |
37
Rep 401
I pulled some errors from Inpa this morning from the information memory, there were no codes in the regular error tab.
I was hoping for some help in understanding that they meant. Thanks. I N F O R M A T I O N M E M O R Y --------------------------------------- Date: 09.04.2014 06:23:22 ECU: GS19B JobStatus: OKAY Variant: GS19B------------------------------------------------------------- RESULT: 4 error in error memory !------------------------------------------------------------- 5113 info counter 2 - DME-forced highswitching Error counter: 32 1. Umweltsatz Mileage 76368 km Gearbox Oil Temperature 80.00 degrees C substrate temperature 84.00 degrees C condition WK torque converter-clutch controlled 0-n Type of Shift Type of Shift 5 after 5 0-n Status Substrate temp. (0=OK, 1=F/ES) 0.00 0/1 status transmission oil temperature (0=OK, 1= F/ES) 0.00 0/1 Status Park block sensor (0=OK, 1=F/ES) 0.00 0/1 Status Position sensor (0=OK, 1=F/ES) 0.00 0/1 Status Turbine speed (0=OK, 1=F/ES) 0.00 0/1 status output speed (0=OK, 1= F/ES) 0.00 0/1 2. Umweltsatz Mileage 84200 km Gearbox Oil Temperature 80.00 degrees C substrate temperature 84.00 degrees C condition WK torque converter-clutch shut 0-n Type of Shift Type of Shift 6 after 6 0-n Status Substrate temp. (0=OK, 1=F/ES) 0.00 0/1 status transmission oil temperature (0=OK, 1= F/ES) 0.00 0/1 Status Park block sensor (0=OK, 1=F/ES) 0.00 0/1 Status Position sensor (0=OK, 1=F/ES) 0.00 0/1 Status Turbine speed (0=OK, 1=F/ES) 0.00 0/1 status output speed (0=OK, 1= F/ES) 0.00 0/1 3. Umweltsatz Mileage 117184 km Gearbox Oil Temperature 21.00 degrees C substrate temperature 21.00 degrees C condition WK torque converter-clutch open 0-n Type of Shift Type of Shift 1 after 1 0-n Status Substrate temp. (0=OK, 1=F/ES) 0.00 0/1 status transmission oil temperature (0=OK, 1= F/ES) 0.00 0/1 Status Park block sensor (0=OK, 1=F/ES) 0.00 0/1 Status Position sensor (0=OK, 1=F/ES) 0.00 0/1 Status Turbine speed (0=OK, 1=F/ES) 0.00 0/1 status output speed (0=OK, 1= F/ES) 0.00 0/1 forced step up 5-6 by DME Test conditions not yet fulfilled Error present now and already stored Error would not cause a warning lamp to light up Error code: 51 13 78 20 25 4A 78 7C 25 40 29 1D 78 7C 46 00 39 38 3D 3D 01 00------------------------------------------------------------- 4F86 transmission ratio symptom speed monitoring Error counter: 4 1. Umweltsatz Mileage 105976 km condition WK torque converter-clutch open 0-n Type of Shift Type of Shift 3 after 4 0-n actual engine torque 96.00 Nm Gearbox Oil Temperature 10.00 degrees C Output Speed 1344.00 rpm 2. Umweltsatz Mileage 115584 km condition WK torque converter-clutch open 0-n Type of Shift Type of Shift 3 after 4 0-n actual engine torque 108.00 Nm Gearbox Oil Temperature 17.00 degrees C Output Speed 1408.00 rpm 3. Umweltsatz Mileage 121104 km condition WK torque converter-clutch open 0-n Type of Shift Type of Shift 3 after 4 0-n actual engine torque 104.00 Nm Gearbox Oil Temperature 10.00 degrees C Output Speed 1376.00 rpm symptom gear monitoring Test conditions not yet fulfilled Error not present now, but already stored Error would not cause a warning lamp to light up Error code: 4F 86 38 04 33 BF 0A 31 32 2A 38 70 0A 34 39 2C 3B 22 0A 33 32 2B------------------------------------------------------------- 5119 Reset at the Bosch SW-part Error counter: 2 1. Umweltsatz Mileage 123968 km Engine speed 640.00 rpm Output Speed 0.00 rpm timepoint des Resets Reset in use 0-n last exception number before reset 255.00 - 2. Umweltsatz Mileage 123984 km Engine speed 704.00 rpm Output Speed 0.00 rpm timepoint des Resets Reset in use 0-n last exception number before reset 255.00 - probably undervoltage in Cruise oder Limp-Home Test conditions not yet fulfilled Error present now and already stored Error would not cause a warning lamp to light up Error code: 51 19 74 02 3C 88 14 00 03 FF 3C 8A 16 00 03 FF 00 00 00 00 00 00------------------------------------------------------------- 5118 info counter 1 - EGS-Reset Error counter: 2 1. Umweltsatz Mileage 123968 km Gearbox Oil Temperature 35.00 degrees C Battery Voltage 14.72 Volt substrate temperature 36.00 degrees C time after reset/ignition OFF-ON 60.00 ms 2. Umweltsatz Mileage 123984 km Gearbox Oil Temperature 65.00 degrees C Battery Voltage 14.56 Volt substrate temperature 67.00 degrees C time after reset/ignition OFF-ON 60.00 ms EGS-Reset Test conditions not yet fulfilled Error present now and already stored Error would not cause a warning lamp to light up Error code: 51 18 78 02 3C 88 4B B8 4C 02 3C 8A 69 B6 6B 02 00 00 00 00 00 00 ================================ |
06-25-2015, 10:11 AM | #2 |
36
Rep 216
I know it's been a while but did you ever get to the root cause of these codes? How did you resole it? My information memory looks about the same
