2010 2011 BMW 5 Series Forum F10 F10 535 with M5 343M. My New Rims for Summer - Must. Dodge. Potholes. |
04-07-2014, 12:47 PM | #1 |
88
Rep 145
Drives: F10 BMW 535 x-drive
I was running Beyern 20" Mesh rims for a couple years and had all sorts of problems. I managed to bend all four of them (because they are literally made out of butter) and needed something else. Something stronger. Something that would give me the OEM+ look i'm after. So, after a few months of looking and debating between Vossen CV4's, MORR VS8.2's, and OEM 343M rims, I decided to pull the trigger. Let me know what you guys think.
Specs: OEM 343M rims with Bridgestone Potenza RE 760 Sport's Front 20x9 ET34 245/35/20 Rear 20x10 ET34 285/30/20 |
04-07-2014, 06:02 PM | #2 |
66
Rep 188
Drives: 07 E60
Looks clean. I like them.
04-07-2014, 06:03 PM | #3 |
66
Rep 188
Drives: 07 E60
Are you running any spacers
04-07-2014, 06:07 PM | #4 |
88
Rep 145
Thanks a lot. Nah, no spacers and perfectly flush front and back. I've driven under load too and no rubbing either.
04-08-2014, 10:29 AM | #6 |
1569
Rep 29,202
Looks great with those wheels.
04-08-2014, 10:45 AM | #7 | |
88
Rep 145
Thank you, sir! |
04-12-2014, 08:00 PM | #8 |
Rep 9
Do you have springs or factory ride hight? The car looks like it sits perfectly! my one concern with putting these wheels on my 550xi M sport is that I will have unsightly wheel gap...
04-12-2014, 08:37 PM | #9 | |
88
Rep 145
One note though: if you get OEM 343M wheels for your 550, you will need some small spacers in the front to clear your brake calipers. I think 3mm ones will do the trick. |
06-06-2014, 12:55 AM | #10 | |
633
Rep 1,083
How much of a gap is there in the front and back, between the fender and the tire I have the same rims with the 245 PSS upfront on my 535 xdrive and I can stick 4 fingers between the front fender and tire. Could it be because I still have the 295 tire in the back? (285 is on order) |
06-07-2014, 01:03 PM | #11 | ||
88
Rep 145
06-08-2014, 12:01 AM | #12 | |
633
Rep 1,083
As for the 245 in the front... does it look like the 245 is a little more stretched than the 285 in the back? I'm considering using a 255 upfront. To make the front and back stretch look the same, also to protect the rim just a little more. Hoping that the 255 will still be OK with the ACS springs. |
06-09-2014, 08:18 PM | #13 | ||
88
Rep 145
06-10-2014, 04:23 AM | #14 |
1569
Rep 29,202
Here the xDrive actually comes with 245/275 staggered wheels and tires if you have the m-sport package.
06-10-2014, 03:44 PM | #15 | |
1718
Rep 5,110
A 255/285 (20") setup has around 1% difference f/r, allmost twice of the OEM 245/275... |
06-10-2014, 07:10 PM | #17 | |
88
Rep 145
