2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Upgrade stock speakers
      04-07-2014, 10:59 AM   #1
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [7.68]
Has anyone upgraded the stock speakers yet?
If so, what did you get and how expensive was it?
Thanks for the information in advance.
      04-07-2014, 11:21 AM   #2
M.barnes
41
Drives: 123d
i have just found part numbers for the HK tweeters for the doors, and the covers, going to get them i think, but that will probably be it. just a bit of extra sound stage will do for me!
      04-07-2014, 11:26 AM   #3
darkerosxx
37
Drives: '14 M235i
Please post pics or a DIY for that! Would love to see it and do it, myself.
      04-07-2014, 01:20 PM   #4
M.barnes
41
Drives: 123d
Will do. If it's like the e82 wiring will all be there
      04-07-2014, 04:44 PM   #5
DanG
DanG's Avatar
2018 BMW M2  [7.68]
From what I understand, the door has a 3 way speaker in it. So there are three speaker behind the grill including a tweeter,
      04-08-2014, 01:36 AM   #6
M.barnes
41
Drives: 123d
None hk cars don't have a seperate tweeter pretty sure on that. The standard door speaker may be 3 way? Never heard of a 3 way speaker
      04-08-2014, 09:15 AM   #7
DanG
DanG's Avatar
2018 BMW M2  [7.68]
Here is the focal replacement: http://www.focal.com/en/47-k2-power
      04-08-2014, 02:49 PM   #8
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
You mean a coax speaker? Never even heard of a 3-way coax 4" speaker.
Pretty sure it's like the rest of the non-HK vehicles. Same speaker locations, but different speakers being used and no center channel speakers. (Edit: take that back... I don't see a speaker location for the tweeter on the A pillar... what a disappointment, as I can't even leave out the HK option and upgrade without having to deal with subpar speaker locations... the base system probably doesn't even have underseat subs?)
I have a pair of the very last Diamond Audio Hex S400 components that I might try to fit into the factory locations and get a pair of replacement underseat subwoofers, but most likely all that would require an external amp since the Hex speakers are 4 Ohm and the original speakers are 2 Ohm, which means the Hex will be getting even less power and are probably less efficient than the stock speakers.
      04-08-2014, 03:19 PM   #9
darkerosxx
37
Drives: '14 M235i
Stock does have sub under driver and passenger seats.
      04-08-2014, 03:57 PM   #10
M.barnes
41
Drives: 123d
Stock setup has subs and has tweeter wiring in a pillars you just need to buy tweeters and new grills
      04-08-2014, 04:21 PM   #11
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
Thanks. That helps ease some trepidation. Guess I will have a faux HK system when I get my car.
      04-08-2014, 04:42 PM   #12
DanG
DanG's Avatar
2018 BMW M2  [7.68]
Just took of the door panels to see what was really there. The door has one 4 inch paper speaker no tweeter. Quite different than the 3 way speakers I was told. No wonder why the sound is so bad.
The rear deck speakers are also 4 inch speakers.
      04-08-2014, 04:54 PM   #13
darkerosxx
37
Drives: '14 M235i
Please do some replacements and post a DIY!
      04-09-2014, 03:38 PM   #14
M.barnes
41
Drives: 123d
My HK Tweeters and grills arrive for the weekend so will get some pics when fitted.
      04-09-2014, 04:51 PM   #15
darkerosxx
37
Drives: '14 M235i
Where did you order them? Do you have part numbers?
      04-10-2014, 07:32 AM   #16
dmboone25
dmboone25's Avatar
4972
Drives: 2024 Golf R / 2022 718 Spyder
2007 E92 328i  [10.00]
2007 328i  [10.00]
+1 on the grills - are those available through any BMW parts store?
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
      05-13-2014, 09:20 AM   #17
bman6074
103
Drives: 14 M235i and 07 Lotus Exige S
Do you know if the wiring for the tweeters in the Apillars is Hot (live)? Would it be as easy as just getting a set of 1 series Apillar speakers and installing them?
      06-01-2014, 08:07 AM   #18
M.barnes
41
Drives: 123d
No wiring in the a pillar for tweeter. The tweeter wire comes on the tweeter, then you need to buy the hk mid which has an in and an out plug, one for sound in, one for tweeter out.
In the process of fitting mine but the little blue two pin connectors are a PITA. Can't work out how to disconnect the speakers without breaking the connectors
      06-01-2014, 08:13 AM   #19
DanG
DanG's Avatar
2018 BMW M2  [7.68]
We had to cut the connectors and replace them when I changed my speakers.
      06-01-2014, 09:26 AM   #20
bman6074
103
Anyone have pics of the wiring in the door and triangle.
      06-01-2014, 10:16 AM   #21
DanG
DanG's Avatar
2018 BMW M2  [7.68]
As stated above, there is no stock wiring in the triangle without ordering the HK option.
      06-02-2014, 08:42 AM   #22
bman6074
103
Ok, I was looking for photos to see if it would be easy enough to get a component system speaker in the door and separate the mid in the door and the tweeter in the triangle above. Wondering if there is enough space for the crossover box.
thanks
2addicts
