Mod that pays for itself
04-05-2014, 08:59 PM | #1 |
Rep 106
$5 can of Liquid Wrench Silicone Spray.
I just sprayed a rag and applied to all of my door and window seals. MY SQUEAKY, CREAKY CAR NOW SOUNDS LIKE IT WAS CARVED OUT OF A SINGLE BLOCK OF STEEL. If you want to have some fun with this, try doing one side, then drive around and listen to the difference. I'd say that doing this makes my car feel like it is worth twice what it was worth before. |
04-05-2014, 09:19 PM | #2 |
870
Rep 2,615
Or just a regular silicone grease. When detailing the car, I treat all rubber seals to replenish them, look like new. Just don't get any on windows. Also, when hood or trunk struts go weak, spray some at the shaft seal and they work like new.
04-06-2014, 05:55 AM | #4 | |
158
Rep 866
This is what I would use: Wurth Rubber Care Silicone Free Wurth is a great company for plastic and rubber in my experience. I also swear by their lubricants. PL |
04-06-2014, 06:59 AM | #5 |
Jumping Jack Flash
324
Rep 1,692
Drives: 2021 X3 M40i
For this purpose I bought this stuff called "Gummi Pflege Stift" but haven't actually applied it yet.
2021 X3 M40i: M Sport Differential, Adaptive M Suspension.
Previous BMWs: 1971 BMW 2002, 1973 BMW R75/5, and 2011 BMW 335d Previous Other Vehicles: '67 Cougar, '70 911e, '86 Jetta Diesel, '05 and '12 Foresters, et al. |
04-06-2014, 07:46 AM | #6 | ||
96
Rep 1,592
Drives: 2011 335d, M-Sport
Silicone can cause swelling and stress the materials. As you can imagine, the vert folks are pretty meticulous about this. Here's Kat's write up. Some notes from the thread... "A couple of words about products to use on rubber seals: Silicon is a natural enemy of rubber. It makes rubber swell and fracture. Whether your tires or your door seals – do your car a favor, spend the few extra dollars to get good products." Recommended Materials... Gummi Pflege - <$10 Krypton GPL205 - circa $22
04-06-2014, 10:57 PM | #7 | |
Rep 106
I will get the good stuff and clean immediately. |
04-06-2014, 11:34 PM | #8 |
Rep 53
My mechanic recommended Pledge Wipes for my convert and it worked quite a bit but didn't fix everything. Note: a convert has 100 yards of squeaky rubber trim.
04-07-2014, 05:52 AM | #9 | |
Jumping Jack Flash
324
Rep 1,692
04-07-2014, 09:17 AM | #10 |
96
Rep 1,592
The vert folks seem to be using it as a two-stage process. Gummi plflege first, GPL205 second.
04-07-2014, 04:53 PM | #11 |
870
Rep 2,615
I have used it for over ten years and have not had any issues, Always thought that it was mineral oils that would swell rubber, but then it does not mean that I am right. Not that I always trust this, but here is a rebuttal:
http://en.wikipedia.org/wiki/Silicone_grease http://www.silicone.jp/e/catalog/pdf/grease_us.pdf |
04-09-2014, 07:15 PM | #12 | |
96
Rep 1,592
Only one way to find out I wonder if I still have my old cowl seal for testing. |
06-01-2014, 11:17 PM | #13 |
BMW Advanced Diesel, 2011 BMW 335d M sport...
87
Rep 783
So what is the best product for this then, name a few different ones...
BMW Advanced Diesel, 2011 335d M sport...
