2010 2011 BMW 5 Series Forum F10 Drivetrain Malfunction on 2011 535i |
03-31-2014, 09:40 PM | #1 |
Rep 13
Hi all,
I own a 2011 535i Sport 8AT with 54k miles (out of warranty...) I just received a message for drivetrain malfunction, please drive moderately. There seems to be no vibration or abnormalities other than the fact that the car is noticeably weaker in power. Do you know if this was ever issued a recall, or should I try to save money by taking it into an independent shop? Thanks! |
03-31-2014, 10:24 PM | #2 |
powerhouse
708
Rep 1,628
Drives: 2014 Porsche 981 CS
hope it's not the injectors.
some of them need all the injectors replaced. imo it should be a recall but i don't think it is since they only address it "as needed". if it is the injectors, i would make a big deal about it and see if they would do it anyway since it's a common problem. good luck.
no signature. except for this one.
04-01-2014, 11:41 AM | #3 |
373
Rep 1,698
A lot of these drivetrain malfunctions seem to be attributed to failed injectors, but that seems to be most popular on the pre-LCI 550 (N63 engine) that was using the last generation injector.
On the LCI 550 (N63Tu engine) the injectors have now been updated to the same used in the N55, which haven't been prone to failure - not that they can't fail, but don't seem to be unusually problematic. I would imagine the 2011 535 was using the N55, correct? Nal13 on this board (who has an LCI 550) recently reported an injector issue that eventually lead to a buy-back of his brand new car. So, maybe we're not completely out of the woods yet with injectors... but the N55 has been around since the LCI e90, and seems to be pretty solid. So... The drivetrain message can appear for a number of different reasons that posters have reported - some minor, some very major (up to and including one guy who had a complete engine rebuild... again, an N63 550 though). I would just take it in to BMW and have them diagnose it.
2017 BMW 650xi Gran Coupe | MSport | Exec Package | Driver Assist Plus | ACC Stop & Go | Adaptive Drive | B&O | Night Vision | Cold Weather | Active Seats
2015 Audi R8 V10 | Brilliant Red on Black | S-Tronic | Carbon Sideblades | Carbon Trim | Full Leather | Sport Exhaust | Illuminated Doorsills | I-Pod | Contrast Stitching Previous: '14 550xi, '07 335i, '01 325i |
04-01-2014, 12:33 PM | #4 | |
22
Rep 585
2013 535 X Drive, Alpine White/M Sport/Executive/Apps/Black Dakota/Fineline Anthracite
04-01-2014, 12:33 PM | #5 | |
22
Rep 585
04-01-2014, 04:34 PM | #6 |
8
Rep 33
It's unfortunate that such a great car company has not figured out these problems. (I have the same issue on my 2011 550i 3rd time now... I mean nothing compares to my 550 i...i love everything about it but this reliability stuff is important when the car is $80,000....Am i the only one that feels that way????
04-02-2014, 12:59 PM | #8 | |
28
Rep 395
2011 535i xDrive, Dark Graphite Metallic, Veneto Beige Dakota Leather, Technology Package, M Sport Package, Executive Package delivered Christmas Eve '10, Mods - quad tips, 20% tint, JB4.
04-02-2014, 04:07 PM | #9 |
373
Rep 1,698
Yes, I'm aware - as I said in my response, the N55 should have the same injectors on the N63Tu, hence eliminating some of the suspicion around injectors being the problem here.
04-02-2014, 06:15 PM | #10 | |
Rep 13
I just had a mechanic read the codes and he said it was some misfire codes? |
04-02-2014, 06:26 PM | #11 |
Rep 13
As far as I know, the battery was never changed in the car. The CARFAX does not list a battery replacement either. I am hoping this is just it!
07-16-2020, 04:37 PM | #13 |
17
Rep 30
i know its an old post but just stumbled upon it....a pressure converter is a boost solenoid basically. thats the main cause of these errors.
if you scan and get a code on ISTAD "120308 Charging pressure control, plausibility pressure too low". this is an indication of bad solenoid. it will run around 50 bucks non OEM to 180 bucks OEM. non OEM works just fine asn even the OEM fails. its located on left side of the engine on N55 right below the intake hose at the lip of the engine valve cover. |
08-21-2020, 02:38 PM | #14 |
Rep 12
I just got my 535i and had this when I was going on the highway going over 90KM. It would happen consistently. Turns out it is the boost pressure selenoid that needed to be replaced. Once that was replaced, the issue was fixed.
