Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > 335D Catch Can Install Completed.
      03-29-2014, 07:08 PM   #1
135i_vs_
135i_vs_'s Avatar
Drives: M5, 135i, 335d, F10 550xi
Took the whole day and a few trips to the auto store, but got it done.
Definitely a PITA due to the cramped space in the whole engine bay. I was lucky to be able to tuck it behind the air box. Looks pretty stealthy. I will be able to measure the oil in the can with the dipstick. Dipstick is accessible without removing the top cover.
The biggest problem I had was finding the right fittings.
The routing of the inlet hose should not cause any pooling.
Thanks to the Pioneers of the catch can install on the 335D, I had the motivation to do it.
Let's see how it goes over time.
      03-29-2014, 07:10 PM   #2
135i_vs_
135i_vs_'s Avatar
Some helpful dimensions for the catch can installation.
This is the OEM hose that is being replaced:
      03-29-2014, 07:17 PM   #3
Puerto Rican 335d
Puerto Rican 335d's Avatar
Puerto Rico
229
Drives: Montego Blue 335d
Wow great job
      03-29-2014, 07:44 PM   #4
Got_Diesel
20
Drives: 335d
that area gets VERY hot being right next to the turbos....
Hope it holds up and lets see how well it works.
      03-30-2014, 06:34 AM   #5
135i_vs_
135i_vs_'s Avatar
Its not next to the turbos.
Keep in mind the intake siencer is right there, so it pulls air from there under vacuum.
      03-30-2014, 06:54 AM   #6
TDIwyse
614
Drives: 2011 335d
Tight :-)
How do you have the can fastened down in there?
      03-30-2014, 08:05 AM   #7
2deerwhistlers
109
Drives: 335d
Next to the turbos should keep the whole system from freezing up.. On a 12v dodge the heater lines run directly over top of the exhaust manifold and that's just regular heater hose with steel tubing (Which I've run egts of 1750 F multiple times a day)..the BMW has heat shields and such mounted over all that turbo mess.. Nice install!
      03-30-2014, 08:15 AM   #8
135i_vs_
135i_vs_'s Avatar
Originally Posted by TDIwyse View Post
Tight :-)
Tight indeed, lol.
It held by friction, the can diameter fit just right, no vibrations or movement.
If I'm correct, your can is in a similar location.
Thanks. That's what I was thinking, little bit heat would be good in the winter.
I'll upgrade the lines next week to steel braided 10-AN.
      03-30-2014, 10:30 AM   #9
WreckerX5d
Warrant Officer
WreckerX5d's Avatar
Drives: Deezul
Looks like a clean install. At least in a week we'll see how much has been caught already.
Deleted, ATM I/C and tuned by B.R.R.
      03-30-2014, 10:44 AM   #10
Nushibo
Nushibo's Avatar
23
Drives: 335D
2011 BMW 335d  [0.00]
Niceee!! You can remove that tube on the intake box by the way. Should make access a bit easier. keep an eye on the tubing as well. Even though its next to the silencer it gets pretty warm down there. My can on the other side burns after a long drive lol.
      03-30-2014, 11:04 AM   #11
JP-76
Drives: 335i
I dont think those rubber hoses are going to last long. As you can see in the last picture of the first post, the heat coming between the turbo and the heatshield has already melted a little dent on the airbox cover...
That crack is like a torch on a hot day when you are driving "in a spirited way"
Present: F30 335XiA M-Sport Individual
Ex: 335dA Individual MY2007 "LCI"
      03-30-2014, 12:21 PM   #12
135i_vs_
135i_vs_'s Avatar
Good observation. Have to visually take a look and see; don't remember there being any damage to the air box from heat.
As I mentioned, upgrading to steel braided hoses next week. This is temporary.
      03-30-2014, 01:27 PM   #13
JP-76
Drives: 335i
I noticed that because I have the same dent exactly in the same spot
Its caused by the heat from the turbos... Maybe you could wrap some heat reflection tape to those new hoses on that critical spot
      04-01-2014, 07:46 AM   #14
Nushibo
Nushibo's Avatar
23
Drives: 335D
Out of curiosity what hoses are you using? Trying to find a solution to pooling for my setup, also where did you get them.
      04-01-2014, 11:47 AM   #15
135i_vs_
135i_vs_'s Avatar
I am running 5/8" heater hoses. However, I will be swapping out the hoses next week to nylon braided AN-10 hoses (5/8"). They will be must more durable and resistance to heat.
For your pooling, you basically have to route the hoses so all the oil flows to the can (decline). Where my catch can is, it flows at a decline to the catch can.
I saw your setup, you will get a little bit pooling, and it may not be an issue since the hoses are large enough, and eventually will flow to the can.
      04-01-2014, 12:05 PM   #16
Nushibo
Nushibo's Avatar
23
Drives: 335D
Yea I drained the system before putting it back in. Only a few drops sit in the elbow. Im going to find either another elbow or a larger hose to set it to a decline. Thanks for the info ill be searching around now. Also the BMS can is should have 5/8 inch OD for the inlet/ outlet. Hence why 3/4 fits so easily around it.
      04-01-2014, 12:12 PM   #17
p27rpy
Drives: 2020 BMW M2C
Nice work! Catch can is on the list as soon as I'm out of warranty (with a few other things as well).
      04-02-2014, 10:13 AM   #18
135i_vs_
135i_vs_'s Avatar
I switched over to these elbows last night. I want to say, they are a perfect fit. It was very tight to get them on, requires no clamps at the input and output.
So far everything is holding up well.
      04-04-2014, 01:34 PM   #19
2deerwhistlers
109
Drives: 335d
Nice! Where'd you find them?
      04-04-2014, 02:06 PM   #20
135i_vs_
135i_vs_'s Avatar
Only place I found them was from Advanced Auto Parts, and they had to special order it for me. Took about 4 days to get.
So far they are hold up great, no issues.
      04-04-2014, 02:10 PM   #21
Nushibo
Nushibo's Avatar
23
Drives: 335D
Just redid my setup again for a third time. Squeezed the 3/4 over the top connector no more pooling! I hope
      04-04-2014, 04:16 PM   #22
135i_vs_
135i_vs_'s Avatar
3/4" hoses? Post a pic.
