Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > iDrive continuously freezing
      03-28-2014, 07:35 PM   #1
pantera chris
E90 330i 6spd manua
pantera chris's Avatar
United Kingdom
Drives: E90 330i 6spd manual
Have an issue where my iDrive seems to be freezing every 10-30 seconds. The radio/music will cut out for a couple of seconds and then come back on again. When the music goes off the idrive controls are unresposive.
I have sat nav (which still seems to work) and bluetooth.
Additionally when the music turns off you can hear clicking noises coming through the speakers. These clicking noises continue even when the car is off and the key is out!!
Anyone got any ideas. I have reset the idrive and it has no effect.
      03-28-2014, 09:58 PM   #2
thatdudejim
Drives: BMW 328xi
Not sure about the idrive but mine also goes unresponsive at times. For the clicking noise, is it directly from the speakers? I know for my car it sounds like it keeps reading my nav disc. It only stops when I take the nav disc out. Try taking your nav disc out and see if the clicking stops?
      03-29-2014, 02:48 AM   #3
pantera chris
E90 330i 6spd manua
United Kingdom
Clicking happens with disc in or out
      03-29-2014, 07:16 AM   #4
pantera chris
E90 330i 6spd manua
United Kingdom
Ok this was the Bluetooth unit in the boot under the center hatch causing the idrive to freak out. I disconnected the unit and the idrive has been absolutely fine since. I hope this helps people as I've seen a few people talk about this issue but no fixes.
      10-06-2014, 04:09 PM   #5
hossamyazeed
Drives: E90 320i
hello guys , any updates regarding this issue ? i have same problem .
regards
Hossam
      10-06-2014, 04:24 PM   #6
pantera chris
E90 330i 6spd manua
United Kingdom
Err well it's the post above yours...
      10-07-2014, 01:46 AM   #7
hossamyazeed
Drives: E90 320i
thanks for your feed back,
do you mean remove the center console and disconnect the Bluetooth unite
http://postimg.org/image/41ajnl3gj/
[IMG][/IMG]
regards
      10-07-2014, 01:49 AM   #8
pantera chris
E90 330i 6spd manua
United Kingdom
It's in the center of the boot under all the carpet and stuff. Silver box. Unplug everything from it and it should sort your issue. The units cost about 150 to replace
      10-07-2014, 08:06 AM   #9
hossamyazeed
Drives: E90 320i
problem solved .... thank you very much for your guidance
      10-07-2014, 08:15 AM   #10
pantera chris
E90 330i 6spd manua
United Kingdom
No worries, took me ages to get to the bottom of it. Glad I helped someone else.
Tags
crashing, freezing, idrive
